Got the entire engine all buttoned up, the Canton tray, Spott's scraper, Milodon pan, Milodon pick up, Dynagear pump, dipstick tube(s), & all seals blueprinted and JAM UP! Looking real good w/ required tolerances.
But guess what I find that I forgot??? My damn oil pump drive!!! Whaddaidiot! So now rather than dissassembling the pan assy. I'm thinking about removing the two swaged protrusions on the upper shaft & installing it from above. Anyone think this will present a problem in operation? Obviously we ain't purposely running it upside-down. Whaacuthink? SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY. I Misus Rash'!
SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY! |
No it will work fine from what i have been told.
Althoe i figure they put those bumps on the shaft for a reason...Maby its just in case you flip it upside down so the shaft wont fall out. But i dont see it presenting a problem since the pump is bolted in and the Dist will be bolted in dont seem like there is any way for it to come out. Mike |
That's what I was thinking. But gotta run it up the flag pole, just to see who salutes.
Any other opinions? Not about me being an dumbass, we've already established that. SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY. I Misus Rash'!
Larry, I read somewhere, but I can't remember where (CRS) to grind off the tangs, drop it in and don't worry about it.
(CRS) = Can't remember ****! My Rig's a little old, but that don't mean she's slow.
WWW.PatriotGuard.org Standing for those that stood for us. Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I. One for your soul; the other for your freedom |
Larry, I'd bet there are more than a few who have frgotten the oil pump shaft at least once, but won't admit it. Some 25+ years ago I was helping my best friend assemble his '67 GTO engine and we forgot the shaft. He ground off the two tangs and dropped it in. Ran for many years and miles like that!
Lloyd '72 Formula 400 - soon to be a 455HO, TH400, A/C, etc.; Lucerne Blue with Medium Blue Interior Restoring a '72 GTO 455HO, TH400, A/C, etc.; Sundance Orange with Parchment buckets
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
O.K. - I'll admit to doing the same thing! Ground them little sucka's off ,stuck it in and no problems. Bill--
GT37 3600lbs...as featured on the cover of Pontiac Enthusiast Jan/Feb 2002 DOT/mufflers-all motor 6.49 @ 108 10.14 @ 133
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk 1.35 w/29.5x10.5x15 6.42 @ 109 10.09 @ 133 |
Those tags are to lock the shaft in place so it doesn't come out with the distributor. You don't need them. Just make sure the shaft is in place when you put the distributor back in.
Why is he not suspended? |
I've done this for years thru many engines with no bad results. Get u a good extended type magnet that will hold the rod by itself, take a lite and note the position of the oil pump drive. Ease the rod in the hole with the magnet and use a long flat head screwdriver to adjust the rod a little to get the rod to drop on the drive. When it drops in the slot hold the rod with ur screwdriver and take the magnet off. Use ur screwdriver to turn the rod and make sure it is in the rite position. U can get the rod off to one side, but iv'e never got one stuck or dropped one into the pan.
wanna race? gimmie the move--
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
I have dropped one into the pan doing that once...that is one thing I will NEVER forget!
The engine was already in the car and hooked up, it was one of my first rebuilds. Went to put the distributor, and no shaft...talk about pissed. But when I dropped it in the pan... Determined no to pull the engine, it took me about 3 hours to get it out...jacked the engine up, dropped the pan...etc, etc... Good luck and be careful not to drop it!
"Artificial intelligence is no match for natural stupidity." |
I belong to that club too!
No problems yet, distibutor pulled plenty of times. MOTOR CITIES FINEST PHS Documented "REAL JUDGE" 12.53 @ 110.68 on street tires, through the mufflers and a 4 speed!!
Worlds Fastest Documented GTO JUDGE! |
Glad I'm not the only one.
I'm pretty sure the trick to install the shaft comes from pete mccarthy's book.I forgot the shaft too once.
See, some of us are not too cool to admit we make mistakes! I too have to admit I have done it and survived!
I have a oil pump driveshaft in my GTO from HO Racing. It doesnt have any tabs at all. I tried to make it fall in the pan while the engine was still on the stand but it wouldnt. Different diameter maybe? You out there Ken?
http://www.machdevelopment.com/album...775/527566.htm |
What a relief! I was contemplating giving up drinking while working on my cars.
Well for a minute or two, anyway. SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY. I Misus Rash'!
Larry, Being a "Dumb A$$" would involve running
the engine and wondering why you had no oil pressure. (Chebby guy drove around one time with an LS-6 engine for a while until he burned out every rod and main after he did not put one in his engine). Have NEVER forgotten to put the oil pump drive in BUT only because have seen it done several times by others. As you can see you were not alone on the board in this mistake. Agree only possible issues would be dropping it in the pan on installation and having the same thing happen on distributor removal in the car. Tom V.
Pump shaft snafu's:
Put one up in a dark garage from under the car, later when attempting to start the engine it spun a half turn and hit a hard mechanical stop Turned out it had missed the hole and was instead wedged between the rear most cam lobe and the block-one junked cam and a bunch more work. Forgot one just like Larry and dropped it in from the top. Worked like a charm the first time. Later I pulled the distributor for something and while I had it out decided it would be a great idea to run through the valves. Bumped her over and heard a metallic thud as the rod fell into the pan Not fun getting it out with the motor in the car but it was possible. Lessons I've learned. You band-aid your mistakes now but if you've my luck it will bite you in the a$$ later when you can least afford it The secret to happiness is not getting what you want but rather, wanting what you have.
The secret to happiness is not getting what you want but rather, wanting what you have. |
After having a OP driveshaft break on me and having to pull the motor to change it I ground the tabs off of mine just in case I ever have one break again.
Bartman Ponies run but Birds fly
Ponies run but Birds fly |
Just did the same thing. Ground mine off too. Just be careful removing distributor. There is an access hole in the back of the block that you can get to and hold the shaft if the engine is out and the the trans or bellhousing is off the block.
Phil "dreamed I was wide awake........woke up and I was sound asleep"
"dreamed I was wide awake........woke up and I was sound asleep" |
