hey everyone got a little question for ya i just got done putting a set of timing gear drives in my pontiac 455 and didnt have a gasket to use on the timing cover nothing was open to get a new one and the old one was no good so i decided to use ultra blue gasket maker ???? do you guys think that it will hold up as well as a gasket
i think black is a bit better but since i dont like dishing out $$$ for gaskets especially when they just come in a set...i make/cut my own gaskets out of the gasket paper you can buy at the autostore and black rtv for the timing chain cover...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun... |
I use Ultra Blue exclusively. I just like the color . I have used it for timing cover's no problem. The best way I have found if your going to be just using RTV for a gasket, is to spread a thin coat on both surfaces to be mated. Let cure for 10-15 min, to form a 'skin' on the silicone. Then assemble the pieces. This method seem's to work well in my experiences.
I have mad timing cover gaskets out of gasket paper when nothing was open.They have a seam at the top but they still work fine.
I prefer "The Right Stuff".
Darin '64 Bonneville Wagon (sold) 69 Lemans-All motor (sold) 9.81 @ 136.39MPH |
I've used RTV - Blue, Black, Clear, and Form a Gasket and have never had a leak from any of the mating surfaces or joints.
You know it's going to be a good day when you wake up breathing! |
I also like the Right Stuff. 500 miles so far on my 467 and not a leak anywhere(not even the rear main, probably just jinxed myself). Only problem with it is that it's hard as heck to remove. I did just take off my water pump and plate to check the clearance to try addressing it running a little warm and used the blue stuff putting it back together. Sealed up fine.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
