Who makes them and who sells them? Thanks.
I have a Miloden pump on my 455..
It's really a GMP unit.. I've heard you can order em from Napa or Autozone.. I don't know the PN though.
William's Law-- There is no mechanical problem so difficult that it cannot be solved by brute strength and ignorance. Scott Schering Http://www.pontiacs.org |
Flow Kooler makes one also part #1649. You can get one from Summit Racing 1-800-230-3030. Summit part #BRA-1649 price $79.95.
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ |
i got the flow kooler one and found my car to run hotter than with my cast iron piece that i assume is stock. i would not advise buying the flow kooler. just my experience.
CSI Electric Pump, works great! $179.95 ask for Jason and tell I told you to call him exclusively! He'll hook you up! For more info on the pump,www.outlawpontiacs.com
[ April 12, 2002: Message edited by: Craig Berkheimer ]</p>
Outlaw Pontiac Racers Association "For Those Who Live The Legend" www.outlawpontiacs.com |
I have one of the flow cooler (MADE IN JAPAN) and it didn't help mine,They have the stamped steel Blades not like the ones use on 455 from the factory.And from what I have seen this is alot of overheating problem.Cast iron curved blades were used on the 455 and stamped steel for other ones and when you get a rebuilt one from the auto parts they use the stamped steel ones.Anyone else hear about this issue?I will be ordering the CSI pump,I seen how it worked on Craigs car.
1969 GTO Judge RA IV 4 Speed Windward Blue 1967 Firebird 428 auto 1970 Firebird 455 auto 1998 Trans Am WS6 2005 GTO M6 |
The Flow Kooler pump i have has the cast impeller not the stamped one. If you want some good info on the water pumps, click onto the Heating & cooling Forum, then click onto show topics for the last year. On page 2 a topic named Hot Running Engines will tell you all about the water pumps.
Thanks Robert,I will check it out.
CSI Performance 386-776-1476 (ask for Jason)
www.csiperformance.com
Thanks everyone. Any idea if that electric pump is good for a street car and NOT a race car? I had planned on doing a March Serpentine belt system also and I am not sure that electric pump will work with my set up.
Plus I am just gathering idea's for the time being. The car is a LONG way from being done. Hell, it's a long way from being started. LOL |
On the Flow-Kooler site they show the aluminum # 1649 pump that has the 8 blade cast impeller like the one i bought 2 years ago. The one i have also has the plate on the back of the impeller. They may have changed since then i don't know. I have read that some of the stamped impellers are better designed than others. http://www.packeton.com/flowkooler
