Hello everyone, I have a simple question. I'm installing a 73 Nova 8.5" 10 bolt on my 68 Firebird. The spring perches have four bolts. Well, some of my bolts are in poor condition, are they something I can just pound out and change?
I already thought about cleaning them up, but a few have to much damage. Thank you and good day friends. Michael >>> rr67gto@aol.com Build it fast, build it right, hold On TIGHT !!!
Build it fast, build it right, hold On TIGHT !!! |
i would replace the4 t bolts with u bolts any spring shop can supply them not expensive
pure pontiacpowerd 86 grand am 455 eheads hyd. cam 9.24 at 145
pure pontiacpowerd 86 grand am 455 eheads solid flat tappet cam 8;95 @152 HOFFMAN RACING |
I agree about using u-bolts.
I'm getting ready to install an 8.5 in my 69 Firebird. I figure using u-bolts will be better, especially since I had to relocate the perches to fit in my car. Not that I'm a bad welder, I just feel more comfortable. Now I only need to find out where to get a rear u-joint to use. The 8.5's take a larger u-joint then the 8.2 Any one know where to get a u-joint with different cap sizes?
"Bye" "Bye" Rice Boy!!! |
RR67GTO, yes they are replaceable as the others have stated. If ya want to look original PY has a hardware kit with 2 u-bolts and 4 T-bolts and 8 nuts, also Classic Ind has T bolts avail separately, otherwise it's cheaper to go with local purchase u-bolts! Just be sure top get them from an auto parts store instead of a hardware store!
DanC
------------------------------ 1968 Firebird Convertable - my original HS car! 1978 Firebird Esprit "survior" 1930 Ford Model A Coupe .. (original) 1994 Buick .."TowMaster" ...woody wagon |
marty I put a second gen ta rearend in my friends 68 bird it used the same ujoint but you have to shorten your drive shaft 1 inch.
RR 67
I used to use a driveshaft, with a 1330 U-joint, mated to a rear-end yoke, that takes a 1350 U-joint. Any drivetrain shop will have the U-joint that you need. Bill
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. 8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08 |
I got a U-joint several years ago to adapt a GM driveshaft to a Mopar rearend. I think I bought it at Carquest, but it was a NAPA part.
'67-69 Bird had Spicer 1330 u-joint
'72 & '73-74 Ventura 8.5 had small chebby Spicer 1310 u-joint. '75+ 8.5 GM used Spicer 1330... Simple solution, build rearend with later 8.5 pinion yoke. Make sure & cut 1" off driveshaft if going from 8.2 to 8.5 with original 8.2 driveshaft.
