now that im the proud owner of cast HO manifolds, id like to get them coated.
any recs on who/where to have that done? i did a search here, but almost all repsonses were about headers, and the iron jobs people reference eastwoods SS gray paint.
costs too much |
I've always used the cast coating sold by Eastwood Company. Follow the directions and you'll have no complaints.
Parts for sale!!! chief.thundercloud.fc@gmail.com https://www.facebook.com/groups/Dave...acStuffForSale |
Me too. After a bath with brake clean I put them in the oven at 200 before I painted them.
Mule |
I could be remembering wrong- I thought that when I talked to Jet-Hot a few years ago, they could do cast iron parts.
I've also been quite happy with Eastwood's stainless-steel paint on exhaust parts.
I had mine coated by Jet Hot. Numerous different colors available.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Dave those look sweet!
I have used eastwood and VHT high temp paint both have looked and lasted well.
--------------------------------------------------------- "And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor?? --------------------------------------------------------- |
For those interested, I just called Jet Hot for a quote to have a set coated. $215 for the pair.
Tim
'69 Silver GTO Convt (400/M20/3.55) |
I had mine done last Sept. The basic price was $195 plus an additional $20 to coat the inside. At that time they offered a 10% "internet" discount which put the price at $193.50 plus $25 shipping back to me. $218.50 total. They have had about 1500 miles on them since then and look just like they did the day I put them on. I pulled the engine down earlier this year and had the heads worked and noticed at that time that there was vitually no exhaust build-up on the coating inside the manifolds. Underhood temps are noticeably cooler also.
I had mine powder coated with a higher heat coating, was $80 each. Still look great.
67 GTO Hardtop |
I just picked up a set of R.A.R.E. manifolds for my T/A and had them coated. It cost an extra $200, but they look good. We'll see how the coating lasts once they are on the engine.
Anybody know where I can get the studs where the downpipes meet the manifold? I bought the installation kit, but it came with only bolts, no studs.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone. The frogs take up where they left off. |
I think most of the catalog companies carrie the studs. I believe I got a stainless steel set from Year One. Check around though, I don't think they're that uncommon. Also, I think I Ram Air has them as well.
You may also want to consider getting the bolt locks that prevent the manifold to head bolts from backing out once they're crimped. |
I need the studs that go where I drew the circles.
Thanks SD!
Yup, those are the ones available.
Here's the passenger side installed!
I purcahsed a set of the studs to bolt up the head pipe to the flange from our sponsor. Folks at R.A.R.E. told me that the pipes were connected using bolts in Ram Air cars. Is this correct? Every set of used RA manifolds I see has studs (usually a broken one).
I got mine from our sponsor.
"I know just enough to keep me here, but not enough to get me out" |
Just the studs, the manifolds are RARE ceramic coated.
I painted my "log" mainfolds in 1991 with Eastwood gray manifold paint following the instructions to brush on not spray it on and heat it afterward. They still look new laying on my garage floor today. I replaced them with 67 HO Manifolds earlier this year and used Eastwood on the new R.A.R.E. manifolds.
A buddy of mine sprayed his manifolds with Eastwood last year and they are already flaking and showing some rust spots. Proper application and heating them afterwards is the key. I also like the cost!!!! JMHO... Jim
"Never try to teach a pig to sing. It's a waste of time and it annoys the pig" |
