I have a demon carb on my 64 catalina. I had to add a 1/2 inch riser to clear some fittings, etc. The riser is not metal but one of those composite brown one. I have noticed that it(the riser) looks like it soaking up gas (it's turning brown/damp) on the corners where the carb hold down studs go. When it sits for a some time the riser drys out. Should I be concerned? What could be causing this? I have snugged down all the bolts. BTW, I have had this problem/issue for about two years and am just curious if this is normal.
Thanks for any help. karl |
Sounds to me like your dripping raw gas down your intake. Is it just the front or front & back? I would check your float levels first. Then check your float bowl screws might be leaking on the outside and you can't see it.
best 1/4-11.37 @ 118.03, 96 heads on motor. 11.05 @ 120 on 100shot. |
