I am going to be taking a DA sander to my T/A soon and was wondering if using Wally marts sandable primer is acceptable to use? I only have a 5hp(5.9 @90psi) compressor and want to save money by stripping the old paint myself. Well I have to cover it with something after I strip it so I thought I could get away with using that primer.What do you think? My first time doing this and do not know what else to use with limited funds and resources.
going bandit-Reynolds style |
Your compressor will never keep up with the DA sander. I know-- I tried it once with a 5.5hp/6.4cfm compressor. You'd also be better off using a metal prep solution instead of the cheap primer. That'll give you a better starting point for the real primer you'll need later on. Hope this helps
_____________________________ 69 GTO #1: White 350hp/Auto 69 GTO #2: Brown/White 2-Tone 350hp/4spd |
Eastwood sell's some primer for a good price. check them out.
"Soid like a rock" |
I thought you were teaching a class on Walmart. Can't find stuff in those big SOB's.
http://kurtspontiac.homestead.com/DavidJones69GTO.html
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
I used Duplicolor rattle cans on the 68. I bought the primer sealer ones. Supposed to seal out water. Looks good, but I am stripping it off once I get it painted though
1968 GTO 1972 LeMans "Where's Fast70TransAm??"
1968 Pontiac GT0 1972 Pontiac LeMans Heart Of Illinois GTO club member "This aint no damn Chevelle" |
Yeah if you use the spray can primer be sure to strip it off before you put on the good primer or paint.I tried painting over some a couple times and for some reason that cheap primer makes the paint crack as soon as it`s sprayed on.
www.cardomain.com/id/gto_guy
www.cardomain.com/id/gto_guy Everyone should believe in something,I believe I`ll have another drink. |
It'll be ok for inside storage if you strip it off again before you put down the real primer.
If it's going outside I'd get some self etching epoxy primer.. it won't chalk up over time and wash away. PLus you won't have to strip it off again.. GURU: One who knows more jargon than you Scott Schering 70 Firebird 455 12.34 @ 108.2 Http://www.pontiacs.org
William's Law-- There is no mechanical problem so difficult that it cannot be solved by brute strength and ignorance. Scott Schering Http://www.pontiacs.org |
I'm doing dp90 for now. i dont want to waste money on primer until i finish all my body work. there is no point to waste money,but that into your car. I would fix all the rust and body work. then strip it down when you have the money. I've wasted so much money in the past buying primer
22 bar roll cages in the works |
