I just got my 455 back from the machine shop and I want to get some opinions on it before I start to build it.
Here is what I have: 455 bored .040 over (465 CI) '46' heads with a 3 angle valve job, comp 995 dual valve spring, stock rockers and with roughly 9.7:1 CR CC XE274 cam and hyd. lifters Reconditioned stock rods with ARP bolts and KB pistons Stock crank, grinded and indexed. Edelbrock Performer intake Edelbrock 750cfm electric choke I have a TH350 with a 2200 stall and 3.08 in the rear. Also any HP guesses or 1/4 times?
With the tune dialed-in and adequate traction, it should be capable of solid mid-12's. That is, of course, "corrected to sea-level" times!
I've seen some slightly milder combos run low-12's, with some really good tuning & driving. I'm guessing that you'll use some good headers & exhaust system. Lee
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
73 Firebird, Nice set up . I live in Roy, Utah and have a 67 GTO with a stroked 400 in it. Email me if you want to compare cars and talk Pontiacs sometime. Mike gto67cpe@aol.com
400 stroked to 467 ci KRE alum heads, Dougs headers, etc. 500 dyno HP |
Thanks for the response Lee. I forgot to mention I'm running Doug's coated headers and have the Pypes 2.5" X system.
67gtocpe: Hey it's nice to see another Utahn on here. Too bad my car is down in Spanish Fork or you could see it (if it ran). I work up on the Army reserve center up in Ogden. Maybe I could stop by sometime and check out your car. I'm still an extreme beginner so maybe you could teach me the Pontiac ways. Morty4@hotmail.com
Nice build.
Uneasyrider
Uneasyrider “To find yourself, think for yourself.” ― Socrates “The unexamined life is not worth living.” ― Socrates “Wise men speak because they have something to say; fools because they have to say something.” ― Plato |
