Quick question. I was picking up a can of an "almost chrome" product at my local body/paint supply shop and talked to someone who suggested using a 3M metal body repair tape. It's a flexible thin tape that has shiny metal on one side and adhesive on the other. What do you think about just lining the inside with this stuff?
Also, the "chrome" paint I got didn't have a max temp spec listed. Any harm in using "standard" stuf like this for inside the lens? Thanks! Mark
71 Firebird Custom - Fuel Injected & Over-drived! |
that paint works well for reflective purposes. Just don't out think yourself and try to clear over it !!! Bad news (
Pete's Ponies Mustang RUSToration & Performance |
I used the "almost" chrome paint to refinish the inside of my tail lamp reflectors.The body tape would work good on a flat surface but too many wrinkles on a curved surface.
Eastwood sells a reflective aluminum paint just for lenses. I used it on my car, it is brighter than almost chrome.
eastwoodco.com |
I used Alclad II paint on my dash. I believe that it is the closes thing to chrome. They sell it at Hobbly stores. Works great on plastic I'm not sure about metal application. The key is a nice smooth gloss black finish to apply the chrome over. Check out the link.alclad II
az67goat,
Do you have pictures of the results?
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by az67goat:
I used Alclad II paint on my dash. I believe that it is the closes thing to chrome. They sell it at Hobbly stores. Works great on plastic I'm not sure about metal application. The key is a nice smooth gloss black finish to apply the chrome over. Check out the link.http://www.alclad2.com/index2.html <HR></BLOCKQUOTE> Did you use a gloss black enamel under the Alclad II? Any other prep? Did you have to polish it after it dried?
A bad day fishing beats any day working! |
I'll try and get some pictures done by tonight or tomorrow sometime.
I sanding down to the plastic. Painted gloss black Lacquer. No polishing. The key is to get the surface very smooth before the black gloss lacquer is applied. I used 800 grit. You could go finer. Pics later... |
Hope these pics help give you some idea. I painted all the trim area around the wood insert and around the guages, Not as good as vacuum metalizing but...
Here's another...dark but reflective.
Wow, that did turn out really nice. Thanks for posting the pics. I think I will go that route as well. Cliff
i went to a craft shop. they sell chrome felt tip pens. like a magic marker. works like a champ. real easy to use.
