My 63 Lemans convertible is starting to sag in the rear after 40 years of use. I noticed that the previous owner placed some spacers in the coil springs to give it an extra boost, but the car still sits at least 2 inches lower in the rear than the front. With the car having a rear transaxel, What is the best way to get the back end up where it belongs? New coil springs, air shocks, shocks with the helper springs?? If it needs new coil springs, where can I purchase them and how much am I looking atfor a cost. Dan
1969 Ram Air III 4-speed 1963 Lemans Convert #'s Matching 326 V-8 1949 Pontiac Silver Streak |
check Hemmings for springs.I had a set done for the front of my 63 Lemans.Tom
I have some stock springs ,came out of a 63 v8 car with a manual trans and low miles
How much do you want for the springs?? I'm leaning at putting air shocks on the car, but have not explored if they will fit on this car. Dan
i'll take 50 + shipping
You may try checking a Moog or TRW distributor.
They are obsolete, but someone just may have a set sitting there. The part number for all except Safari and 8 cyl convertible is #5111. Safari and 8cyl convertible is #5109. That is the same numbers for either Moog or TRW. Jerry |
Thanks Jerry for the help. I'll get back you your Frank63 if I'm interested in your springs. Dan
anselcop check www.kanter.com they have your coilS for your 63 lemans for $185.00 AND THATS THE PAIR THATS THE GUYS THAT I USED FOR MY FRONT END GOOD LUCK!
