This may be a pretty basic question but what's the difference between an "N" crankshaft and a forged one. I noticed in the "for sale" forum Ken has an "N" crank for sale at $750 and another fellow has a 455 forged crank for $1,500.
69GPModJ Moderation in everything--including moderation. WC Fields. |
the N crank is a castiron crank and the other is forged steel.The forged is WAY stronger.Tom
S' what I thought but wasn't sure.
Thanks.
what about cast N/IRON vs cast STEEL?
The "N" stands for nodular iron.
NHRA tech. "Its just a 412, I swear it". Pontiac tip of the year, quit those damn cigarettes. |
I would double check the 'forged steel' crank to make sure it is in fact forged steel. F/steel 455 cranks are scarcer than rocking horse $h*t!
If your talking about the 455 stroker crank I got for sale.
It's a 455. 3.250 mains with a 2.50 offset cut for BBC rods and.......... hard chromed by Crankshaft Specialists in Tenna. Did it way back in the 90's for a combo that was never built. Cost me $550.00 to have done, plus $50.00 to ship it back home. Stronger then a regular N crank, but definately not a Steel crank. But then again, depends if it's a twisted forged steel crank or not. |
Geoff,im sure Joe has it,I bet it is a Kellogs from engineering.I have a 3in main 4.21 stroke RA V developmental crank.Tom
Yep, it,s a forged Kellogg unit.
Kerry the real question is what are your plans. Are you going to make big HP numbers or is this to be just a street motor. Many people have used cast cranks with 700+ HP with out any issues. A forged crank is nice and it can’t hurt a thing, but will your needs require such an expensive crank in you motor?
1994 Formula 535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200 Pontiac Powered 4th Gen Project Progress |
WARPed:
Eventually, I want to build an engine with about 1,000 streetable HP and I've been talking with Dave Bisschop at SD Performance about an IA block. I've posted some questions in the Race forums before about supercharging & so on. It's clear I'll need either a good forged crank or a billet one but right now I'm still just look'n. Gotta pay off my current engine before I start building the new one LOL!
dont treat me like a red-headed step child still wondering, which is better, A GOOD N CRANK or a CAST STEEL EAGLE?
there both good for their intended use.The std. pontiac crank if checked and preped is good.The cast Eagle cranks if checked and preped are good also.If you want std. pontiac rod and main size the stock crank is fine for limited HP.If you want a stroker crank or BBC rod size the Eagle is a better buy.IMO,Tom
thanks TOM, i was thinking the same way. my N cranks are good. i haven't gone fast since 93. not even sure which class to run yet. want to start out 10's flat NA without breaking parts & go from there. i'm still trying to relearn the math part,LOL. my ruff finish is 4.245. i'm looking at rotating assemblies available. exmample: 461-477, but thinking it would be better to go with a shorter stroke to square the engine. 3000-3500lb TA with a/t & 3.70, modified mostly stock suspension.
What motors came with forged crankshafts?
If its one thing I know, its..... Uhhh I forgot . What do you mean I couldnt be the president of the United States of America, Its still WE THE PEOPLE, RIGHT!! |
lugnutt, The '59-'62 389SD, '61-'63SD, and the '69 RA V, both 303 & 400.
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. 8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08 |
Thanks WD!
to add to what Bill said,early cranks from 57-58 were forged,maybe the 55-56 also.Tom
Not much choice for lowend cranks right now is there?
For chinese steelcranks RSB is the only ones I found available. Eagle, Scat, Cat, Ohio seem to be out until a boat arrives and they can be machined.
My Daddy bought me a car but all I got was this old Pontiac. |
