I've noticed when starting my car that the engine has what sounds like a knock. The sound lasts until the engine is warm and then it seems to disappear.
I've changed the oil about 6 times since rebuilt (2,000 miles ago--long story why so often) and never found any excess material in the pan or in the filters (dual system). I'd characterize the stuff I find on the magnetic plug as a very fine powder. When I wipe it off the plug, it turns into a silver paste on my fingers. There isn't a lot of it either--maybe enough to cover three-quarters of my thumb print. Here are some specs: - Solid flat tappet cam with about 250 duration & 540 lift (rockers about 0.002" to 0.003" more play than recommended by cam manufacturer) - HS roller rockers - 0.025 clearance for both mains & rods - side-to-side rod clearance checked out (though can't find the numbers anywhere) - a bit more piston to cylinder clearance than normal, as I plan to run nitrous once in a while - top ring gap of 0.022" - bottom ring gap of 0.024" I plan on using a mechanics stethoscope to have a closer listen but, in the meantime, any thoughts?
69GPModJ Moderation in everything--including moderation. WC Fields. |
Lifter adjustment.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Sounds like cold piston slap to me.
Ever hear an older Hi-Perf forged piston chebbie engine upon cold start?
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
"Cold piston slap" If that's what it is, can I "live" with it for a while or is it something I need to worry right now? I'll probably tear the engine down in a year or two anyway.
You can live with cold piston slap pretty much indefinately. Some new ls1 cars do it new from the factory. Given you have a solid cam, it could be that, check lash and if it's ok I'd ignore it as long as it doesn't do it when the engine is warm.
The crashes people remember, but drivers remember the near misses. |
Well, I finally got around to adjusting the valves. That isn't the problem. I've still got the noise.
Also, now I've listened to the engine cold and hot with a mechanic's stethoscope. The "knock" when cold is audible without the stethoscope. When hot, you can't hear a thing without the stethoscope. On the other hand, with the stethoscope you can hear a very slight knock at the #2 cylinder when you touch the block close to the pan. If you touch the block close to the pan on the #1 cylinder, you don't hear anything. When you listen close to the head, you can't hear a thing (except valve train noise). Oil pressure is good--40lbs at idle, 60 to 65 cruising, and around 80 when you step on it. No debris in the oil or filters. Thoughts? I may pull the engine apart over the winter for peace of mind but don't really want to. That'll be the fourth time in a year I've pulled the engine.
Your gonna tie my record Kerry! It's a pain in the @ss, but the "peace of mind" factor is worth it. Good luck.
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something." |
