I'm going to use a Torker 1 this year and am wondering if this is to much intake for my combo (see below). I haven't heard anything good about this intake other than it's good for nothing. Is it that the runners and plenum area are to large?
I was going to gasket match the intake to the head, but I was thinking that if I leave it somewhat smaller, (about 1/16" smaller than the runners in the head). I thought that this would keep the flow up a bit. Any thoughts? '73 455 .030, stock cast pistons, stock rods all ballanced, 86 cc 6X 8 2.11/1.77 hand ported,stock intake,750 Qjet, SpeedPro 1175 cam, 3.73:1 10 bolt posi, slapper bars, MT ET Streets, Best ET 12.12 Best 60'1.43 Top MPH 109
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something." |
You should only have one "pinch point", or venturi, in your induction system (intake and head). Your intake to head flange point isn't it. Get them as close size wise as you can.
Only way to know what will work for your specific combination is to try it, or find someone that has the exact same combo that already has. PY's first and ONLY real, live celebrity. If you don't know, you better ask somebody! |
Thanks Bruce, I had planned on gasket matching, but read somewhere that the Torker had too big a runner cross sectional area as well as plenum area. Also read where there is a different line of thinking with respect to nt gasket matching, although they didn't give the reasoning behind it. I used it last year for a time, but had also changed cam timing at the same time. I lost about .4 in the quarter.
I didn't have time to work on tuning as this was the end of the season. So I don't know if it was the Torker, cam change, or both, or if I could have tuned the .4 back. '73 455 .030, stock cast pistons, stock rods all ballanced, 86 cc 6X 8 2.11/1.77 hand ported,stock intake,750 Qjet, SpeedPro 1175 cam, 3.73:1 10 bolt posi, slapper bars, MT ET Streets, Best ET 12.12 Best 60'1.43 Top MPH 109
It all depends on your cam and heads as far as cross section goes. How much velocity can they build in a certain space. Combination specific.
I usually wouldn't say port match something, but at least get it closer. One change at a time, brother! PY's first and ONLY real, live celebrity. If you don't know, you better ask somebody! |
I bow to your wisdom, oh illustrious one, just not while your behind me.
See signature for Torker I performance. Most relevant is 12.00 @ 112MPH seems to match your 12.12ET
Runners were-high-port matched to high ported 48 head. Frontal Carb flange area was oened up to allow nearly a direct Primary downflow into Runners 1 & 2. HIS "tbdET/1xxMPH/1.xx 60foot/28"/3.54:1/10"/469 #48/Flat HYD/DualQ-Jets/Offyl/3xx0Lbs 11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/469 #48/FlatHYD/DualQuad/Wenzler/3250Lbs 12.00/112MPH/1.61 60foot/26"/3.31:1/10"/469 #48/FlatHYD/Q-Jet/Torker/3650Lbs 12.70/103MPH/1.71 60foot/28"/4.10:1/12"/469 #48/FlatHYD/Q-Jet/Torker/3950Lbs"
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
HIS, my 12.12 was done with my stock 74 intake. I'm going to do some testing with both of them this year. Both will have divorced water cross overs and heat cross overs removed, so it will be easy to switch.
I was toying with the idea of adding a devider to the Torker and make it more like dual plane. Ever hear of anyone doing this? '73 455 .030, stock cast pistons, stock rods all ballanced, 86 cc 6X 8 2.11/1.77 hand ported,stock intake,750 Qjet, SpeedPro 1175 cam, 3.73:1 10 bolt posi, slapper bars, MT ET Streets, Best ET 12.12 Best 60'1.43 Top MPH 109
I thought I read somewhere here that the flow should be from a smaller port to a slightly larger port. The intake port of the intake manifold should be slightly smaller than the intake port of the head and that the exhaust port of the head should be slightly smaller than the exhaust port of the header. I believe the reason behind it was to reduce reverse flow. I always assumed that the gasket would be matched to the larger ports. Correct me if I'm wrong cause I'm still putting my new motor together and that's the therory I've been going with. alan
I match the roof and the common wall as closely as possible. The floor and the pushrod side can be left alittle smaller.
75bird 7.41 1/8mile at 92mph street car 73Ventura 11.88 at 113 streetcar 69GrandPrix 12.64 at 107 tow car 65GTO 10.14 at 129 tri-power dragcar |
