I am about to drop a rebuilt 455 with a Comp Cam 268H grind cam into my '70 LeMans Sport convertible, which was equipped with a 350-2bbl.
This is a mild street engine - driveability and good torque is most valued. I have an Edelbrock Performer aluminum manifold, but have not yet acquired a 4-bbl carburetor for the new motor. I would like to maintain the original throttle cable and choke linkage setup if possible, just because I'm a tad lazy and prefer not to mess with existing setups. I'm considering using a Quadrajet (I have had good experiences with them in the past) I have seen that Edelbrock, Jet, and others offer 'remanufactured' Q-jets, http://www.jetchip.com/fuel/streetmaster750.cfm Edelbrock: Specifically states that they are NOT for non-chevy applications: http://www.edelbrock.com/automotive/carb_qjet.html http://www.edelbrock.com/automotive/carb_qjet_ref.html but I'm not sure these have the same fuel inlets and linkages as the Pontiac setups. Or is it just that the jetting is different? Is this 'doable' - how hard is it to find Pontiac-specific Q-jet carbs from the local parts counter? Is it a major pain to make the non-pontiac versions work on a pontiac setup? Or is it just a matter of getting the right linkage bracket from PY? (I see that there have been references to these in various forum posts.) If not a Q-jet, are there any other carbs that are recommended in the 750-800 CFM range? Thanks for any constructive feedback! -Mike
Bought: 1970 Le Mans Sport Convertible (second owner,) Palladium silver, 350/2bbl (sigh) with Comp Cams 268H grind (installed by previous owner), TH350 Trans. Mods: Front suspension: Global West negative roll tubular upper arms, Del-a-lum bushings, Koni shocks, 12" disc brake conversion, 1.1" front sway bar, Rear suspension: Global West tubular control arms, springs, sway bar. Exhaust: Flowmaster 2.5" American Thunder system. Mostly complete: Firewall-forward engine compartment restoration |
Don't buy a quadrajet from one of the chain parts stores. They are often butchered and the needle and seat assembly is sometimes converted to a press in kind with O-rings. The metering rods are most of the time generic and made of cheap material. If you are going to go to the trouble of replacing the manifold, get a good carburetor from a reputable source. The q-jet is a good choice but not if it has been whacked on by a cheap rebuilding service.
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Randy Frazier:
Don't buy a quadrajet from one of the chain parts stores. They are often butchered and the needle and seat assembly is sometimes converted to a press in kind with O-rings. The metering rods are most of the time generic and made of cheap material. If you are going to go to the trouble of replacing the manifold, get a good carburetor from a reputable source. The q-jet is a good choice but not if it has been whacked on by a cheap rebuilding service.<HR></BLOCKQUOTE> Thanks for the info - which confirms what I've already thought. Now, if I could get a response to the original question about fuel inlet and linkage compatibility... <img src=http://www.exodus-dev.com/teletactics/personal/cars/images/tn_LeMans_edges.JPG> http://www.teletactics.com/personal/...ans/index.html
DIY - I didn't answer your question when you posed it, as we have never had an edelbrock Q-Jet in our shop; and therefore have no first hand experience. But rereading a number of posts from Cliff, and others; I believe that all of the edelbrock Q-Jets are side inlet.
Maybe Cliff will jump in here and post. Jon. Good carburetion is fuelish hot air.
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
Mike:
Do yourself a REALLY big favor and use a Q-Jet. I'd look for a good used or NOS '68 - '71 year carb to have the best compatibility with your throttle cable, etc. Hopefully carbking or Cliff R. will jump in here with more and better advice than I have. I see ads in Hemmings, POCI, etc. for Q-Jets all the time. Be prepared to spend some serious $$$ for a really good used/reman carb from a reputable source, or even more $$$$$ for a NOS unit. But in my opinion, it's the best way to go. To prove that I practice what I preach, here's a pic of the '73 SD Q-Jet 455HO in my Formula. See sig below for performance numbers. Hope this helps, Lloyd '72 Formula 455 - TH400, 3.08 posi, A/C, Y99 suspension, tach & gauges, AM-FM stereo, 8-track, Formula steering wheel, etc.; Lucerne Blue with Medium Blue deluxe Interior; 12.96 @ 104 MPH @ the '03 PSN's Someday I'll be restoring a '72 GTO 455HO, TH400, A/C, etc.; Sundance Orange with Parchment buckets
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
Jon:
That's what I've also heard concerning the Edelbrock Q-Jets - side fuel inlets (chebbie style) only. Lloyd '72 Formula 455 - TH400, 3.08 posi, A/C, Y99 suspension, tach & gauges, AM-FM stereo, 8-track, Formula steering wheel, etc.; Lucerne Blue with Medium Blue deluxe Interior; 12.96 @ 104 MPH @ the '03 PSN's Someday I'll be restoring a '72 GTO 455HO, TH400, A/C, etc.; Sundance Orange with Parchment buckets
