Old 12-23-2003, 01:49 PM
disc0monkey's Avatar
disc0monkey disc0monkey is offline
i have a '71 400 auto with a/c
the interior fan switch doesn't work it is always on low. should i replace the switch or the relay thing, they are like 40 bucks so i would like to know which one. or could it be something else?
Old 03-16-2004, 07:22 PM
anyone, now the fan doesn't work at all!! help
Old 03-16-2004, 08:58 PM
PonchoV8 PonchoV8 is offline
I went thru that and changed a fan. It still didn't work, so I pulled the relay pack out of the suitcase under the hood and cleaned the coils up and replaced it. I thik I started with another car's relay pack, cleaned it up and pu tit back.
Old 03-16-2004, 09:16 PM
thanks ill check it out tomorrow
Old 03-17-2004, 11:06 AM
where is this suitcase?
Old 03-17-2004, 02:08 PM
It's the black case that sticks out on the pass side from the firewall. this one is removed and sitting on the front tire(no fender). The relay pack is the orangish/redish thing with about 4 plugs stikcing out. That's where the wiring harness plugs into. I think it comes out with a 5/16" or so wrench.
Old 03-17-2004, 03:22 PM
thanks for the detail and the pics!! i guess i got something to do tonight
Old 03-17-2004, 05:50 PM
seems to be the problem, i was cleaning it then it worked but then i broke it, im gonna order a new one...thanks
do you know where i can pick up a new one other than ames?
[This message was edited by disc0monkey on March 17, 2004 at 06:01 PM.]
Old 03-24-2004, 08:27 AM
got all of them to work but high, now low and high doesnt work, only the middle ones do. the plug is pretty beat up. i was checking the volts and it seems all of the plugs are getting power except number one which is the offset one, and that one should be high.
Old 03-24-2004, 08:31 AM
i had all of them working but high, now low doesnt work either. i checked the voltage and it seems the one that is offset is high and it doesnt have power. does anyone have a diagram so i can figure out what is happening? also when i put it on high the relay near the engine on the firewall clicks, but only for high...
