Old 11-25-2003, 01:46 PM
Guest
Posts: n/a
I am rewiring a '66 Lemans Convertible and have installed a new convertible top switch. According to the liturature, the power feed for the switch connects to a "junction block," on or near the firewall. It appears that, at least in cars with power seats/windows, the junction block was a circuit breaker - but its not clear if that was also the case in cars where only the top was power (some indication that the power top switch is wired directly to battery power).
So, I do not have power seats or windows - how do I hook up the switch? Do I need a fused junction block or circuit breaker? If anyone has the same car/configuration, I would appreciate you taking a look at your setup and providing advice.
These forums are an OUTSTANDING source of on-the-ground knowledge.
You can post or e-mail me @ djk1966@yahoo.com
Thanks.
Dan
Guest
Posts: n/a
Thanks.
Dan
Old 11-25-2003, 02:17 PM
vidguy's Avatar
vidguy vidguy is offline
On my 67 that does NOT have power windows or locks, the Power Top switch connects via a plug in the harness to a amall 2 post relay of some sort... mounted behind the Brake Booster. That then gets the HOT from the battery directly via an accessory wire from the postitive Battery clamp.
James Fasso
james@icvdm.com
'67 GTO Conv
"I told my parents I wanted to be a comedian
-But they just laughed at me"
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 11-25-2003, 02:49 PM
george kujanski's Avatar
In the '67 manual it says that without power seats and windows it comes from the junction block as vidguy describes. With pw and seats it comes from a circuit breaker in the same location.
The 2 post rectangular device could probably be either; I've seen automotive circuit breakers in that style. It certainly wouldn't hurt to have a circuit breaker in either case.
George
Old 11-25-2003, 03:35 PM
Guest
Posts: n/a
Thanks for checking. I agree that it would probably be a good idea to provide some sort of protection for the power top pump - anyone care to take a guess at the #amp protection I should use? Also - I'm guessing some sort of fused junction block is readily available at my handy local automotive parts store???
Vidguy - can you tell if the junction block has a reset fuse or some other type of circuit breaker?
Thanks again.
Dan
Old 11-25-2003, 03:57 PM
The GM part no. is 1476675 for 68 thru 74. I would guess it would be in the 30 A range. The book doesn't say. I've seen the OEM style breaker in some store, don't recall which. There is also a style that fits in the fuse box; instead of threded studs for the connection it has formed cylindrical contacts that fit in the standard fuseholder sockets.
George
Old 11-26-2003, 10:49 PM
vidguy's Avatar
Sorry for not getting back sooner..
No it just looks like a simple relay or junction block... no fuse or switch visible... I'll check my wiring diagram...c if i can learn anything.
James Fasso
james@icvdm.com
'67 GTO Conv
James
Work
Details here:
Old 11-26-2003, 10:57 PM
vidguy's Avatar
My wiring diagram just says ..."power feed to junction block on firewall.." ...
James Fasso
james@icvdm.com
'67 GTO Conv
James
Work
Details here:
Old 11-27-2003, 12:07 AM
vidguy's Avatar
ok I went out and looked carefully with my flashlight..
on the black plastic itself on my junction block it says:
type 4110
and there is a V and an A under each of the 2 posts..
The A side also says AUX..
And more importantly, on the metal bracket that mounts it to the firewall it says
"40A" Im guessing that means 40 Amps.
If you want a pic I'll take one in the morning..
James Fasso
james@icvdm.com
'67 GTO Conv
James
Work
Details here:
Old 12-01-2003, 03:12 PM
Guest
Posts: n/a
A pic would be great - I was going to go 30A - but will up it to 40A.
Thanks for all of your help . . . hope I can reciprocate someday.
Dan
Old 12-01-2003, 04:42 PM
vidguy's Avatar
I'll take a pic tonight and post it then..
No problem on the help! I love to help in the less involved ways I can... Pictures of metal things screwed into my firewall is easy
Piston ring fit or cylinder pressures... and I'm in the back of the class..
Glad to see a new face on the board anyhow and hope you enjoy it here..
Im in the Bay Area, Maybe we'll run into each other some day on I-5! :-)
James Fasso
james@icvdm.com
'67 GTO Conv
James
Work
Details here:
Old 12-04-2003, 12:38 AM
vidguy's Avatar
Here are the pictures of my Convertible Relay.
Wider
Closer
Sorry for the delay, Hope that helps!
James Fasso
james@icvdm.com
'67 GTO Conv
James
Work
Details here:
