I was thinking about removing the sub frame from my Firebird to sand blast it,paint it and rebuild the front suspension.
The question I have is when I put it back in how do I know its positioned right.I want everything to line up properly.....dont want problems when I re-install body panels. Thanks,Colin
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton "Perpetual peace is a futile dream."-General George Patton "I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson "Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin |
There is only 4 bolts that bolt it to the underside of the vehicle . You really can't miss align it . However you can X measure the front frame horns with your firewall to correctlly square off the front end .
Man is not complete until he's married , then he is finished !
Man is not complete until he's married , then he is finished ! |
Also on the Driver side of the sub frame there is an alignment hole approx 5/8" in dia outboard on the ear next to the mount. Put a large screwdriver or large bolt into this hole from the bottom and into the hole in the body, these 2 holes must be in line with each other then you can torque down the mount bolts. I made my own alignment tool for this, i went to a hardware store Home Depot etc and picked up some threaded rod, can't remember i think it is 5/8" dia. I then cut 6" or 8" lenght off the rod and used this to line up the lower and upper hole on the driver side. With the driver side holes lined up then just install the bolt on the pass side. Now the subframe should be Dead Nuts On with the body.
Robert Williams
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ |
Hey Colin,
Check out my website in my signature below. I'm actually going through exactly the same thing now with my '81 T/A. I'm not ready to reinstall the subframe yet, but I do know it's possible to get it slightly out of line. The bolt holes do have some play in them. I didn't know about the alignment hole trick previously posted (thanks!). I had just planned on measuring it from the edge of the underbody on each side and pulling a string to align it with the rear subframe. If it isn't straight, the fenders can be a b**ch to get lined up straight and if it isn't aligned with the rear subframe, it can "dogtrack" when driving which a front end alignment can usually correct. Good luck! Drag http://webpages.charter.net/dragula7
Drag www.dixiemusclecars.com The Southeast's only online Community dedicated to the American Muscle Car! 2006 PBM GTO LS2 1995 Arctic White Trans Am LT1 1981 Trans Am Daytona Pace Car 1969 Gold Poly Firebird w/400 |
Oh yea Colin,
I thought I would save you some hassle on sandblasting your subframe with a good tip; PRESSURE WASH IT FIRST!!! Sandblasting the PAINT off was a BREEZE!!! All the sand had to do was skim across it and the paint was gone!! BUT, I can't say the same for any grime or grease residue. I had to hold the sandblaster on those areas for a while and SLOWLY move it around to remove it. I DID pressure wash mine first but I missed a couple of small areas. If I hadn't pressure washed it first, it would have EASILY taken me 4 or 5 times longer to blast and probably 5 times the amount of sand. I have a pressure washer at my house, but if you don't have one you should take the time and hassle to throw the frame in the back of a pickup and take it to your local carwash to use their pressure washer. TRUST ME, it WILL be worth the hassle. Good luck again! Drag http://webpages.charter.net/dragula7
Somewhere at home I have the 81 Fisher Body manual.. I beleve it shows the alignment holes and correct alignment measurements..
I'll try and fid it tonight. I thought there were 4 or 6 alignment holes.. 4 in the sub and 2 more back by the leaf spring mounts On my 70 we got the sub under the car and bolted up with a little play then ran it up on the lift. We then adjusted the frame using a big drift through the holes. For the 73 I may try and weld up a jig to drop the body and frame on. Really just a big square frame with alignment pins the frame and body will drop onto. GURU: One who knows more jargon than you Scott Schering 70 Firebird 455 12.34 @ 108.2 Http://www.pontiacs.org
William's Law-- There is no mechanical problem so difficult that it cannot be solved by brute strength and ignorance. Scott Schering Http://www.pontiacs.org |
If your car has been in any type of front end accident, don't use the holes for line ups. Do what one member said, measure from the radiator support hole to the firewall. the front frame-to-body mounting positions are prone to getting pushed by a little during accidents and you won't notice them being bent from just eyeballing them.
Look in the Firebird Supplement to the 67 Pontiac service manual. You can get a reprintof this from Helm at 1 800 782 4356.
I scanned the pages for you. --------------------------- 1967 Firebird 400 conv, 1989 Formula 350
1967 Firebird 400 CV http://forums.performanceyears.com/f...pictureid=6481 1989 Firebird Formula 350 http://forums.performanceyears.com/f...pictureid=6507 |
next page
page 3
