Old 09-16-2003, 08:49 PM
firechicken's Avatar
firechicken firechicken is offline
I'm looking at an "82 T/A and was wondering if someone could tell me what it is.
VIN# 162AW87H3CL566089
Also, this car has a 4-speed manual. I read somewhere that this is a Super T-10. Is this the same trans used in the '70's birds?
Old 09-17-2003, 06:58 AM
the "super" t-10 in the 82 is a lighter unit than the earlier models from what i understand. [ this comes from my trans rebuilder] i'm pretty certain the ratios were different also.
the last couple of issues of hpp had a decent tech article on the 4spds, i didn't read the last installment but it may be worth your while to pick it up for more info.
the H engine code tells me it's a 305 engine, usually that code was carbureted.
hope this helps,
mike
former." --Albert Einstein
- Winston Churchill
Old 09-17-2003, 09:21 AM
That second number (6) is a 'G'.
According to the VIN it's a 1983 TA.
It came with the LU5 305.Made in Van Nuys.
johnta1
Old 12-19-2003, 12:28 PM
Ron22 Ron22 is offline
Here is your car...
Here are the results for your query on: 162AW87H3CL566089
Made in: United States
6 is NOT a known code for the Manufacturer!
Make: Pontiac
Restraint System: Manual belts
Carline Series: Trans Am
Body Type: 2 door coupe
Engine Code: 305 ci V8 LG4 (1982-1984)
3 is the CHECK DIGIT.
Model Year: 1982
Assembly Plant: Van Nuys
Production Sequence: 566089
Ron, Sweden
Ron22
Rather walk with broken legs then drive a german car
Ron22
