I bought a new set of splash shields only to get a set of staples with it. How do you staple these to the fenders through the metal? Does some kind of high powered staple gun work?
Check real carefully on your inner fenders. You should have some holes already there. With some creativity, you can put the sheilds back in the same place.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. ![]() |
I used a sharp punch to make a hole in the shield.Remember they go in from the underside of the wheel well.REAL PITA to do.Tom
Remove all the old staples. Take a pair of needle nose vice grips. Lock a staple into them. Now get a propane torch and heat up the staple. Poke the hot staple thru the shield. Slide a cool staple up thru the fender and the rubber shield and fold over. You might have to clip the new staple down a little. Sometimes they are a little long. Stand back and drink a beer, admire your handy work.
WWW.PatriotGuard.org Standing for those that stood for us. Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I. One for your soul; the other for your freedom |
like bud say"s ,...you can also use tiny drill bit & drill them if they are non exsistant. I had too
Thanks for the help guys.
Small drill bit and a case of beer, do the ones that are clearly visible first
