one piece pan gasket
65 gto 10.75@125 |
Used a few from BOP and the ones from Butler look very similar. They fit and worked good.
Thanks. It has a part no. BOP-0PG49 so it must be the same.
65 gto 10.75@125 |
i just used it, fit good! seems waaay better than the cork and is reuseable. nice piece. be careful pulling it out of the box as it has a steel core that can be bent. - RB
1970 gto (4spd) 462 500 hp 11.940@114.21 / 1.843 60'/ 3980 lbs 1964 corvette roadster 1968 corvette roadster 1962 corvette "equal rights, not equal things" if you want to know the future, read "atlas shrugged" I dont race a 4spd because it is easy, I race a 4spd because it is hard. |
Are you ready to put the pan on that new crank?
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Soon hopefully. You know how it is---things never go as smooth as you think they will. I'll be in touch---give you the details.
65 gto 10.75@125 |
Just put another 1 on my motor but I ordered it from BOP.
Like Jim Robertson was saying, we've used them on several of our motors. Really nice being able to R/R the pan and use the same gasket. I wouldn'd use anything but.
milt |
Thanks for the input guys. I appreciate it.
65 gto 10.75@125 |
Got amy short and sweet install details..I'm guessing you only need sillycone in the corners...??? if there???
