#61
Pontiac's should have Pontiac engines in them, IMHO.
#62
X1000!
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
#63
Or the intake cams on the 4 valve heads that seize up when you run it 1 1/2 quarts low on oil, because they are the last thing to get oil? Or the protruding boss around the spark plug that always burns away when detonation is experienced? Remember, engineers do things for a reason! Seriously though, all engines have their little quirks, but overall, the Triton engine is a pretty decent engine. The Coyote seems like it will be a nice little engine. We are currently building a twin turbo one for 1300 HP. Not a bad foundation to start with.
#64
I would agree,however,i like chevy bodies and Big blocks,but would not have a problem installing a Pontiac engine.
#65
RAV-Z has a Z-28 with a Pontiac Engine going into it again.
I have seen a few corvettes from the early 60s that had a engine swap from a SB Chevy to a 421 SD. The 421 SD being the "Gorilla" at the time. Tom V.
#66
An old customer of mine told me that back in the early 60's, he had a 55 Chevy with a 265 in it that he drag raced. A friend of his told him, "the only thing you're going to beat with that is another Chevy. If you want to go faster, put a Pontiac 389 in it". He did, and said he started running 11's with it!
#67
So here is what i'm looking for....
-Reliable: I do not want to be having to pull the engine I choose down all the time. I don't mind spending extra for rock solid parts, I don't mind a little wrenching and I know what i'm doing but iv'e had a finnicky engine before and it sucks. I also don't have time to be yanking an engine out all the time to take care of issues. I just don't. I understand any type of engine like this can have issues but I don't want constant issues. -Streetable: I want something that I can stick my wife and kids in and not have to worry about failure or other issues. The engine also has to pull enough vacuum for power brakes and run AC and PS accessories without issues. I also don't want overheating issues in bumper to bumper or slow cruise situations. -Reasonable mileage: I have no delusions about making 28 MPG on the interstate with a big Pontiac, even with my 5 speed, tall tires, efi etc. However I don't want to be stuck with something that's getting 8MPG on the interstate either. That said I really want to build a Pontiac. I'm already set up with headers, exhaust, scatter shield, clutch, linkage, radiator, pulleys, wiring etc so it's a drop in deal. I also think it has a lot more cool factor than the LS stuff. That said the LS has proven itself to be able to make great power, reliability, and MPG pretty easily.
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
#68
One of my old street racing buddies in the 70s put a 455 in a 65 Chevelle. Also preferred a 3 speed stick over a 4 speed-back then few folks raced autos.
He was kind of a crazy guy would "lighten" a car by pulling out about half the front sheet metal bolts. Exploded a clutch in his '65 GTO "Purple Haze". Looked like an Uzi got the firewall,floorboard and hood. and his foot.
#69
One of my fellow Pontiac enthusiasts ended up w/ a Mustang w/ a 4.6 in it. He's now retired, but holds an electrical engineering degree, a sharp cookie beyond most....He was having a recall performed on this mustang one day. He asked the service writer which mechanic was the best of the bunch, and if he could go into the shop and ask him a couple of questions, well of course... He asked the mech about the procedure to repair the stripped threads. He basically told him, we drill the hole to the helicoil size and install the helicoil....He asked the mech about the shavings falling into the cylinder??? Well we blow out what comes out, and hope for the best, seldom needing to remove the head(s)....................hope for the best?, now there's a better idea!!!
#70
Let's take gas mileage for a minute and do a little analysis. Say you drive 10,000 miles per year. That is a very aggressive figure for any project car, I'd venture to say less than 5% of cars over 30 years old get driven that much. Let's assume you would get 20 mpg driving an LS and 15 MPG driving a Pontiac. I think those numbers unrealistically favor the LS, but just for the sake of illustrating the point:
10,000 miles at 20 MPG = 500 gallons, $1500 at $3 per gallon. 10,000 miles at 15 MPG = 667 gallons, $2000 at $3 per gallon. At most you are going to save 500 bucks on gas per year driving an LS over an old Pontiac. Considering what most of us have in our cars, I don't know why that would even be a consideration. Also, I seriously doubt you would see a 5 MPG difference if you built two cars identically, one with a Pontiac stroker and the other with an LS, both naturally aspirated and making 550 horsepower. Like I said earlier, my Wrangler unlimited gets 15 mpg highway at 70 mpg in the cold because the aerodynamics are so bad, and my GTO has seen 13 mpg driving at 50 mph with a big Holley running on the rich side. In something with the aerodynamics of an old Pontiac, I'd say you could drive 5 mph slower with a Pontiac engine and you'd make back however much gas money you'd have saved driving an LS. So if you want an LS because you want an LS, put an LS in your car. If you want a Pontiac but are considering an LS to save gas money, put a Pontiac in it. |
#71
From everything I gather, the 4.25" stroke engines are capable of mid teens on the highway. Some claim to have gotten 20+ before but I wont bank on that. With my 5 speed and 28.4" rear tires i'm rolling about 2300 RPM@ 70MPH in 5th. I'm not overly hung up on gas mileage as long as mid teens are a reasonable expectation on the interstate. I do not want an 8mpg gas hog for long drives. I will probably drive an honest 3-4K miles a year.
#72
Hasn't your current 455 been reliable?
#74
the kind of restro mod build the op stated is pretty much what I am doing with a 525 cube aluminum IA II, a set of Lynns v heads, and 6speed tranny. Looking at a dependable 700-750 hp power level with A/C and be able to drive anywhere in comfort if wanted.
I tend to be realistic on how much I will drive this car tho. A daily driver? 50,000- 100,000 miles? Not going to happen. I will be doing that in a big dually or touring type van...something with elbow room.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
#75
I have a friend here with a 66 GTO who has more or less the same reliability goals as you and decided to go Pontiac--aluminum IAII, 505ci, mild cam, fuel injection. It made just under 600hp on the dyno. It's in the car and almost ready to fire up. I'll let you know how things turn out.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
#76
I have a 462 in my 70 GTO. Rotating assembly was used out of an engine I bought in a package deal. Cast crank, H beam rods and Ross pistons. Had the machine work done and built myself. Edelbrock D ports and old faithful roller cam with comp hydraulic lifters. 500+ho/600tq.
I have about 16,000 miles over the last 3yrs and the only issue I have had is at high elevation in heat the fuel will percolate in the carb bowls. Believe I am going to cure it soon by going with intank electric pump (been doing research). Well, my engine does leak but I know that's my fault, hope to get it right on my next build. Also have 5spd and get around 18 mph hwy.
#78
Karl |
#79
Well I agree, swapping in an LS engine is not irreversible. And coolness is a personal opinion. It takes some thinking and engineering to make an LS run in an old car, so that to me is way cool. If it were me I'd have no issue building an LS and dropping it in my car, but I like the engine that I have now so its staying. Plus I like how it looks original. That being said. I'm sure someone somewhere built a poncho that puts down massive power and is dead on reliable.
