Old 01-24-2017, 04:00 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Default Rockers for "big" springs / race engines
I currently have a set of Harland Sharp 1.65's, and I'm sure they are the "Originals". I learned recently that HS also make a "Heavy Duty" version for higher spring pressures.
Got me wondering how many are running or have run the Harland Sharp "HD" rockers?
I understand shaft-mounted rockers are the superior rocker system - they're also way more expensive. I'm interested in stud-mounted systems for roller cams with higher spring pressures (over 200lb seat, over 500lb open).
What's the scoop? Who's are reliable? Any reason not to use the HS HD (part number SH6001-65)?
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 01-24-2017, 07:43 AM
Would not a quick email to the rocker maker give you the low down right from the sourse!?
Old 01-24-2017, 08:16 AM
grandville455's Avatar
Here's the difference in size!
Name:	HS Rockers.jpg
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 01-24-2017, 09:38 AM
Bill Eveland's Avatar
Darby are those the "Diamond" HS rockers?
https://www.summitracing.com/parts/c...w/make/pontiac
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 01-24-2017, 09:55 AM
PAUL K's Avatar
PAUL K PAUL K is online now
We usually use Crower SS rockers with stiff roller springs and have never had a failure.
Go fast, see Elvis!
Old 01-24-2017, 10:08 AM
Bill, Their the HD HS rockers, bought them quite a few years ago from a guy on ebay, then sent them to HS to have new bearings installed.
Darby
Old 01-24-2017, 10:41 AM
I don't think so? I would call them and see tho.
Darby
Old 01-24-2017, 11:50 AM
73T/A 73T/A is offline
I know this is not the classifieds,but I have a used set of the HS heavy duty rockers.Project never happened.Give me a PM if interested.
2001 Trans Am,WS6 Sunset Orange Metallic (sold)
1973 Trans Am 455,4speed
1970 GTO
Old 01-24-2017, 12:05 PM
Steve, I'm looking for real world experience as opposed to marketing sales pitch. I'm sure they would sell them to me touting they would work perfectly. And I'm ok with that, I'd just like to know what common practice is.
Darby, what ratio are those pictured?
Matt
70 GTO 400 4-speed
Old 01-24-2017, 12:50 PM
1.65 Matt
Darby
Old 01-24-2017, 12:53 PM
You would atleast have a base line for what they say both models are rated at psi wise !
Old 01-24-2017, 01:04 PM
Might be of interest. This article lits max open pressure for various companies....
http://www.hotrod.com/articles/hrdp-...r-arm-comparo/
Old information here:
Old 01-24-2017, 10:38 PM
Scorpion RACE rockers(aluminum) are rated to 850 lbs and lifetime warranty. I used them on a 528 Ford I built about 8 yrs ago. Manley Nextec springs Net lift at valve(after lash) was .767" . Advertised ratio was 1.73 but at valve it it was 1.77??. Motor was drag raced one season before he gave that up and put motor in his boat. Its still alive and well.
I also like Crower stainless rockers. Never had an issue with them. IMO the best stud mount rocker...just cost more than aluminum.
Was NOT impressed with a set of Comp pro magnums that were in a friends 351w. Mild hydraulic roller and wheels on rockers were very sloppy after 5000 miles. He replaced them with Crane energizers.
Old 01-24-2017, 11:29 PM
Dragncar Dragncar is offline
I run Norris SS roller rockers. Very nice, stiff rockers with a large bearing. I run them on iron HOs, solid roller with a stud girdle. Lash just does not change really. I check it now and then but do not have too adjust. Wish they still made them for Pontiacs.
Bet the Crowers are similar.
Old 01-25-2017, 03:02 PM
Conflicting data...
http://www.harlandsharp.com/STYLES.html
"Designed for high spring pressure and
High lift geometry, Harland Sharp’s
Heavy Duty Series can withstand over 1000lbs of spring pressure. "
Whereas the hotrod article claims 750 lbs. max rated open spring pressure.
I've also spoke with several using "Origianl" Harland Sharps with high pressure (over 600lbs) springs.
Just food for thought...
Matt
70 GTO 400 4-speed
Old 02-10-2017, 04:40 PM
Default Harland Sharp "Original" vs. HD rockers
Both these are HS 1.65 ratio rockers.
Left is "Original"
Right is "HD/Heavy Duty"
Pictures kinda don't really do justice to how much beefier the HD's are. I'll try to weigh them and see weight difference.
Edit* not sure why first pic rotated but on that one, top is HD rocker.
ID:	446933   Click image for larger version
ID:	446934   Click image for larger version
ID:	446935   Click image for larger version
ID:	446936   Click image for larger version
Matt
70 GTO 400 4-speed
Old 02-10-2017, 05:18 PM
Mike Davis's Avatar
I have run the original HS rockers at around 750lbs spring pressure and have not had an issue.
Last year I went to the Crower Stainless, best move I ever made. Valves stay adjusted and lift is dead on as advertised.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 02-10-2017, 10:40 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
You might have a look at Yella Terra shaft rockers. They're pretty dang nice and the Yella Terra guys are Pontiac guys as well.
Old 02-11-2017, 12:17 AM
73 TRANSAM 73 TRANSAM is offline
The HS heavy duty looks just like Crane Gold rockers
Old 02-11-2017, 01:31 PM
BADDTA's Avatar
BADDTA BADDTA is offline
X2! Running them with 800# over the nose 74-7600 rpm. No issues.
Brian
Boobs & bacon
