Old 05-27-2021, 07:14 AM
jpg69bird jpg69bird is offline
Default Mid 80's Wheels on 2nd Gen
I photoshopped these pics.
Does anyone have actual pics of mid 80's 16x8 wheels on a 2nd gen Trans Am?
Name:	w-Black Cross-Lace.jpg
ID:	567331   Click image for larger version
Name:	w-Silver Turbo 16's.jpg
69 Firebird Conv, 350 HO w/3 on the tree swapped to Tremec 5 Speed - Sold
72 GP, 400 Auto - Sold
09 G8 GXP M6 Orig Owner - Sold
76 Trans Am 455, 4 Speed - Current
Old 05-27-2021, 09:49 AM
78w72 78w72 is offline
heres a few of my 78 with GTA wheels. they look & fit very good & give a little better cornering performance vs 15" tires. i replaced them with the 15" WS6 snoflakes after a reapint though for a more correct look.
Name:	78 ta 1.jpg
ID:	567353   Click image for larger version
Name:	78 ta 10.jpg
ID:	567354   Click image for larger version
Name:	78 ta 12.jpg
Old 05-27-2021, 12:26 PM
unruhjonny's Avatar
The only problem is that the GTA wheels are front and rear specific.
I quite like the third gen 16" wheels, and have dabbled with the idea of modifying my '91 Grand Am to use RWD brakes ect and the Pontiac deep dish directional wheels similar to those photoshopped on the second picture of the yellow TA.
1970 Formula 400
Old 05-27-2021, 12:40 PM
yes GTA wheels are front/rear specific... but they look good with the right combo of 4. the standard 3rd gen snowflakes look good too.
Old 05-27-2021, 08:50 PM
Thanks for the pics. What size tires? I was looking at 235-60-16's.
Did you go with 4 fronts? Do you know if the 3rd gen rears will rub?
Old 05-28-2021, 06:42 AM
The Champ's Avatar
235/60/16's won't fit on the front - they're 27.1" tall. 60 series 16's in that size are more typically run on trucks.
When we first ran 16's on my wife's lowered '72 we had 225/50/16's on the front and 245/50/16's on the rear. The next set of tires were 215/55/16's on the front and 255/55/16's on the rear.
I wasn't running 3rd gen wheels, but IIRC those that did put the fronts on the rear and the rears on the front for proper fitment on a second gen.
Old 05-28-2021, 07:11 AM
Thanks Champ,
Stock, these came with 225-70-15's which are 27.4" tall. Am I missing something?
Currently on my 76, the previous owner put 215-70-15's, which are horrible and look undersized. This is why I am going through the upgrade.
Old 05-28-2021, 09:45 AM
the rims were put on the car from the prev owner before i bought it so cant say for sure what size the tires were.
you are correct that stock size 225/70/15 is 27.4", a 27.1" tire should fit without any problems, even if its 16" wheel. not sure why champ said they wont fit...
the 235/60/16 is only .4" wider than a 225/70/15 but that shouldnt matter either since people run 255/60/15 all the time that are the same basic height at 27" & are 10" wide, .7" wider than a 225/70/15. i know of some guys that run a 275/60/15 on all 4 corners that are 28" tall, looks kinda stupid on the front but they fit on a non lowered car & only rub on full lock of the steering.
if your car isnt too terribly lowered or sagging original springs a 235/60/16 should fit with ease.
Old 05-30-2021, 10:32 AM
I ran 255-50-16s on my 78 TA fronts on the front rears on the rear no issue. OEM/Classic does make new replacements if you want to use zero offset "fronts" all around. Swapping to them vs the old 255-60-15s autocrossing was night and day! Car was fairly lowered.
305-50-16s would not fit on the rear with the "rear" offset had to use "fronts".
Old 06-02-2021, 05:04 PM
A picture.
Old 06-02-2021, 05:11 PM
burd's Avatar
burd burd is offline
Those wheels look good on these cars, I’m tired of snowflakes and won’t run them on mine, I’m looking for same rims in black.
Old 06-02-2021, 05:17 PM
When I autocrossed it I found a cheap IROC Z wheels and used four "fronts" with 23.5x9 road race slicks. Not as nice looking but cheaper and easier to find back then.
Old 08-04-2021, 10:28 AM
erliabol erliabol is offline
Default It looks great
Nice choice of wheels and tires.
Old 08-04-2021, 01:25 PM
thanks. i do like the GTA wheels on these cars, but the 15" WS6 snowflakes look better IMO & are correct so i went with those. plus i dont do any auto-x'ing with this car so im ok with 15" 'tires.
255/60 front & 275/60 rear, no rubbing issues at all & the front is about 2" lower than stock.
Old 08-14-2021, 03:53 PM
Default 80's Wheels Installed
So I went through with it. I restored a set I got off of eBay. Put 235-60-16's on.
ID:	571349   Click image for larger version
