Old 03-17-2024, 11:13 AM
Cliff R's Avatar
Cliff R Cliff R is offline
As far as replacing the excellent factory cast iron intake with a Performer, waste of time/funds. You are putting a smaller intake on the engine so no power waiting for you anyplace. So like the millions of folks before you who own a Pontiac or other Detroit based V-8 engine about all you've done best case scenario is spend a couple hundred bucks to take 27 pounds off the front of the vehicle......
The Following User Says Thank You to Cliff R For This Useful Post:
Old 03-17-2024, 11:15 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I disabled the egr on a `79 301. That motor pinged till I put it back.
The `79 400 didn`t. But, it had a larger cam.
Old 03-17-2024, 11:21 AM
PunchT37's Avatar
I was just following orders.
I would have left it alone if it was mine. Low miles, numbers matching `79 SE, W72, WS6. What`s that car`s production? Maybe 1700 or so?
Old 03-17-2024, 11:46 AM
SD455DJ SD455DJ is offline
Originally Posted by Brock1030 View Post
In progress with re-build on a stock W72 and want to keep it close to that with the refresh. Have read all, if not almost all, of the threads on the plethora of cam choices. Heard the videos capturing the idle on the Summit 2800 and 2801 cams, as well as the Lunati.
Seems wide support for the Crower 60240, though have not been able to find any videos of its idle. Realizing the choice of exhaust will affect the tone, would like to hear the idle sound to see just how smooth. Anybody running that 60240 cam in a 400 and have a vid to share? Kindly advise.
Thanks so much!
If you're keeping it very close to stock using the original log exhaust manifolds and Y-pipe (or true duals), I wouldn't go with any new HFT cam larger than the 2800 myself. You'll only have very low 8's compression like Cliff said, even after a resurfacing. Here are the dyno sheets for the '79 W72 with the original Y-pipe and then with 2.5" mandrel bent head pipes...FWIW. Dan also dyno'd it with RA manifolds to see what improvements they made.
Dennis
Name:	W72 Y-pipe wbase.jpg
ID:	630508   Click image for larger version
Name:	W72 71 Logs wDuals.jpg
ID:	630509   Click image for larger version
Name:	W72 RA man w air cleaner base.jpg
ID:	630510   Click image for larger version
Name:	Dyno - Stock Mockup 1.jpg
ID:	630511   Click image for larger version
Name:	Dyno - Stock Mockup 2.jpg
Old 03-17-2024, 01:08 PM
Brock1030 Brock1030 is offline
Thanks so much for all the responses. This W72 is 4-speed is all stock, including the intake. As for the exhaust, using the stock exhaust manifolds, but then the 2.5” stainless Pypes X-pipe, along with their down pipes (so, no factory Y-pipe) and then the Pypes Turbo Pro mufflers.
Interesting comment, Cliff about the loss of power above 5200 rpm. Since all stock, but rebuilt Quadrajet with the larger 800-CFM carb, standard on the W72, agree some power capacity should remain, though not more than would be expected from a low compression 400, such as this one.
Leaning toward the recommended Crower 60240, as it does seem to have a bit more power down low than the Summit 2800. Good to hear that the 60240 has a smooth idle and has a hint of a larger cam in tone. Would still like to hear one though, a recording of it, if anyone is running this cam on their car. Kindly advise.
Thanks so much!
Old 03-17-2024, 02:29 PM
jhein's Avatar
jhein jhein is offline
OK, so not to hijack, but I have a related question. I know one should not choose a cam based on idle sound. But I also know that people do like the car to sound a little spunky. So usually, if someone wants that sound they go with more duration. What if you did a custom cam and kept the duration low but went with a tighter LSA, more overlap? What would that do? Would it help anything or just make your dynamic compression even lower and run like crap?
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 03-17-2024, 03:24 PM
Steve C. Steve C. is offline
EFFECTS OF CHANGING LOBE SEPERATION ANGLE (LSA) HERE:
https://www.compcams.com/cam-timing-...paration-angle
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 03-17-2024, 04:10 PM
Excellent info, Steve - thank you!
Choosing the cam for the power - relative with these low compression 400’s, I know - but would like some idea of idle, mindful the exhaust note dependent of the exhaust system chosen, etc. Want it to sound smooth and close to stock.
Old 03-17-2024, 06:34 PM
jhein's Avatar
So what do people think about doing something like the '79 W72 cam but on a 110 LSA instead of the factory 113.5? Seems like it might have some benefits for what the OP is looking for without the negative effects of a bigger cam in a low compression motor. Would that be correct or am I missing something?
And to correct myself, I said that it would decrease dynamic compression but I had that backwards.
Old 03-17-2024, 07:22 PM
The tighter lobe separation might be helpful for a lower compression. But in the OPs situation wanting the 'smooth idle' it would be negative because the Idle quality would suffer.
That said a slightly rougher idle might be tolerated by many.
Another topic of interest might be changing to lobes with the same, or very similar, .050-duration but with less seat timing.
And with the same or similar lobe lift, or even adding additional valve lift.
Example, I suspect if you look over the lobes listed here at Bullet you might find something that has the same duration at .050", but with less advertised duration. And again with the same lift.
https://www.bulletcams.com/Masters/HFlobes.htm
This does not necessarily represent any endorsement here, its is offered for general interest only. Also keep in mind Crower, Comp Cams or others will grind custom cams to fit your needs.
Old 03-17-2024, 07:39 PM
jhein's Avatar
Thanks Steve, I appreciate your expertise. I thought the OP also said he wanted a little hint of cam in the idle too, that's why mentioned it. Maybe I got that wrong. Anyway, good thread.
Old 03-17-2024, 07:52 PM
Example, using the intake lobes for conversation in comparing the Crowers tiny 60240 cam to one at Bullet Racing, their HF260/300 lobe.
The Bullet lobe has less advertised duration with 260 degrees but the same 210 degrees duration at .050" lift. It has .450" lift vs Crowers .422" lift, beneficial if it can be utilized.
The only unknowns here is at what tappet lift are the two lobes advertised duration rated at and the .200" duration numbers.
Using the calculators available at Wallace note the affects of the reduced seat timing.
http://www.wallaceracing.com/Calculators.htm
A similar situation could be applied to the exhaust lobes. And again noting any lobe separation desired could be utilized with a custom ground cam.
Old 03-18-2024, 07:31 AM
Actually, the '79 W72's custom Comp Cam was ground on a 110 LSA. It made great vacuum and idled very well. The idea was to build cylinder pressure with only 8.1 compression. Here are the specs.
Dennis
Name:	W72  Cam Box.jpg
The Following 2 Users Say Thank You to SD455DJ For This Useful Post:
Old 03-18-2024, 10:18 AM
78w72 78w72 is offline
Just to add my 78 W72 cam to this thread, I picked a XE268 cam for mine before I read about other options or opinions on the XE cams. It runs very good in all situations with no tuning issues, pinging or being soft off the line, pulls great to 5000 with no hesitation etc. Its a basic build at .030 with TRW/Speedpro pistons on stock rods, 6x-4 heads milled about .025-.030, comp is estimated around 8.75ish. 1.52 comp roller tip rocker with no problems or "blueing" from heat. its a 4 speed.
The carb was set up by Cliff so Im sure that helps a lot, but I dont have any of the problems some claim on this cam, its ran mid/upper 13's at 103+mph, taking it easy on launch due to a newer street clutch & not wanting to hurt the engine or car, just a fun test & tune day to see what it would do. Hard BFG street tires & not very good track prep. Sure does run good for a turd cam.
Old 03-18-2024, 10:54 AM
jhein's Avatar
Dennis
Nice. The results you got for both of those motors was very impressive.
