Old 12-13-2022, 06:43 PM
mpmsmuscle's Avatar
mpmsmuscle mpmsmuscle is offline
Default Best D-Port headers for Kauffman D-Ports
What are the best d-port headers to use with Kauffman D-Port heads 315 CFM. Application is a 69 Pontiac Gto with a 474 stroker, m/t with 600 plus hp. I was trying to find d-port headers with 2 inch tubes. I am running a 3 inch exhaust with Flowmaster Delta Flow 40 series mufflers.
Pure Pontiac Power!!!
Picture of my actual 69 Judge racing in 1970.
Rare Espresso Brown Ram Air III, 4 speed, manual steering with power disc brakes and factory build sheet indicating 4:88 special order rear axle.
Old 12-13-2022, 07:34 PM
25stevem's Avatar
25stevem 25stevem is offline
Here’s a guide.
I do stuff for reasons.
Old 12-13-2022, 08:06 PM
Steve C. Steve C. is offline
As noted above it is the INSIDE diameter. You will have to figure in the material gauge of the header.
Example 18 guage material (.049) on both walls of a 1-7/8" diameter header will be about 1.775".
Old information here:
Old 12-13-2022, 08:43 PM
chuckies76ta's Avatar
https://forums.maxperformanceinc.com...d.php?t=863039
Old 12-13-2022, 09:54 PM
tom s tom s is offline
you can do 2in Dport headers.Requires the Headman 2in adapter plates.I have them on my 63 Lemans.The plates bolt to the heads and the header flanges have the holes so they are EZ to bolt up.Been out for maybe 30 years?You would need to have custom headers built on the car with them I think.Tom
Old 12-14-2022, 10:04 AM
Jay S's Avatar
Jay S Jay S is offline
I think Tom your talking about using d port to round port adapters once sold by headman and Mad Dog? I don’t know the part number. It adapts d port heads to round port headers for 2” headers. Is that made anymore?
On our 68 GTO with d ports we have Mad Dogs. They are step headers, 1.875” for a couple inches out the heads, then 2” primaries with 3.5” collectors. I don’t think Mad Dog makes them anymore, but might be special order. They are a work of art, nicest header I have ever owned. They are used often for stock and superstock.
Old 12-14-2022, 11:02 AM
Actually they make Dport to 2in Dport also.Headman still sells the gaskets for them.Have not checked lately to see if they still sell the plates.Trying to do 1 7/8 or 2 in on a Dport makes getting the 2 center bolts in is almost impossible,is with 2in.With the plates it is beyond EZ.Tom
Old 12-14-2022, 11:08 AM
They still sell the flanges for 2in Dport outer.
The Following User Says Thank You to tom s For This Useful Post:
Old 12-14-2022, 12:57 PM
I believe the technical term is Header Sub-Flanges. I had them on my Headman 1-7/8 race headers for the d-port heads years ago.
Old 12-14-2022, 05:09 PM
ta man ta man is offline
What is your et/mph goal..may be easier just to use 1 3/4 inch? I'm running 10.6's/127 thru 1 3/4 inch headers.
Old 12-14-2022, 05:14 PM
I would use the sub flange even on 1 3/4!Tom
Old 12-14-2022, 05:46 PM
mpmsmuscle's Avatar
Is the sub flange still available? If so where can I purchase? Thanks
Old 12-14-2022, 05:47 PM
mpmsmuscle's Avatar
10.5 to 10.6 is the goal. Are you using the sub flanges? Which headers are you using?
Old 12-14-2022, 06:18 PM
Headman sells them.Tom
Old 12-14-2022, 08:34 PM
wbnapier wbnapier is offline
Here is the link: https://www.hedman.com/product-detail/10170
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 12-14-2022, 08:49 PM
mpmsmuscle's Avatar
Thanks for the help. 😎
Old 12-14-2022, 09:20 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
These would go on my d port `69 GTO.
https://pertronixbrands.com/products...31797115486244
Old 01-01-2023, 07:25 PM
Pic of the plates on a engine run stand.Will run a set of 2 in Tyree Dports on it.Tom
Old 01-01-2023, 07:30 PM
That's a smart product. Should make install easier. Not sure why are manufacturers doen't do a subflange
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 01-02-2023, 01:23 PM
I'm currently using 1 3/4 Dougs...have also used 1 3/4 Super Comps
