Old 04-08-2023, 07:25 PM
mrmark1957 mrmark1957 is offline
Default What P/S and Alt brackets for #13 heads
I'm in the process of swapping a pair of #13 heads in place of the 6X-8 heads on my 400 inch motor in my '73 LeMans. The '73 P/S and Alt brackets don't line up with the bolt holes in the #13 heads. Also the 13's are missing a boss with a threaded hole on top. What should I use to make this work ?
Old 04-08-2023, 07:36 PM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
On the top where there isnt a threaded hole, just turn your long bolt around and run it through backwards and add a nut to the radiator side. It will hold fine and all the other holes should line up to your brackets. Did this on mine several years ago and everything holds tight.
The Following User Says Thank You to 400 Lemans For This Useful Post:
Old 04-08-2023, 09:31 PM
Formulabruce's Avatar
You need a 1970 bracket and PS pump set up to run any 11, 12, 13, 15, 64 etc heads.
This will be a tough find.
Old 04-08-2023, 09:32 PM
The Bottom of the head is missing a important hole for the pivot bracket. Lets see your pics! Thanks
Old 04-09-2023, 09:02 AM
400 Lemans's Avatar
https://forums.maxperformanceinc.com...ator+hole+head Here is a good thread on it.
