Lunati Voodoo 704 Sound Clip
I thought I would share the sound clip to my 462 with the Voodoo 704 on a 110. There’s a lot of cam recomendation threads here so I thought the sound clip would be a welcome addition. The 2.5 exhaust is RA manifolds with a Pypes X and Race Pros.
https://youtu.be/oPlC13g4BCo Thanks to Paul (gtofreek) for the recommendation and Paul K for the Hylift Johnson’s
The More People I Meet, The More I Love My Dogs! |
Man, that sounded good. How does she run? I bet she runs like a scalded dog!
Pulls hard, especially with the 3.73s. It will get 3.08s this winter to appreciate the full power range in a street and highway cruiser.
The More People I Meet, The More I Love My Dogs! Last edited by ponchjoe; 11-11-2017 at 12:50 PM. |
Nice! I used the 703 in a stock RAIII app.
Made over 380 hp on dyno
Carburetor building & modification services Servicing the Pontiac community over 20 years |
That’s pretty impressive, stock heads?
Yes unported,
I was not happy with the pistons owner supplied as they were the TRW's flats and another shop dished them in a lathe loosing the efficiency of squish pad area. I still managed to get 10:1 out of them
Thanks, PonchJoe, for putting up this video. It was just what I needed to hear this morning. Have a 703 still in the box for after the holidays. Your sound clip gives inspiration....Thanks!
Sounds good Joe, I gave it a thumbs up.
Advertised Duration (Int/Exh): 276/284
Duration @ .050 (Int/Exh): 233/241 Gross Valve Lift (Int/Exh): .504/.527 LSA/ICL: 110/106 Valve Lash (Int/Exh): Hyd/Hyd RPM Range: 2000-6000 Sounds great. Good choice on mufflers too. |
Nice!
Some evil magic in that haunting sound. Dare I say VOODOO?
"...ridge reamer and ring compressor? Do they have tools like that?" |
I have the same exact set-up in my 468. Pulls real hard and I know that 770 carb is a hair small. The redline is well over 6K. Love this cam. Youll be way happy!!! I cant keep my foot out of it!!!
Have fun and be safe!!! Mine gets sideways in 3rd!
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
Sounds great. That's not even what I'd consider a really radical idle either, and sounds pretty tame considering the duration and LSA numbers. Did Paul recommend an ICL install position?
Yes he did, 104, but the closest I could get was 104.5
Close enough. You'll enjoy it. Paul has never steered me wrong.
Took the Tempy out today before the rain.. at 65, drop it in 3rd, 5400 is well over 100. Got the car sideways on onramp. Car is wicked fun. You will LOVE that Cam!!
That sounds really great. I was torn between the 703 and 704 for my build. I ended up going with the 703 because of the 5 speed and 3.36 gears I wanted the cam to smooth out by the time I was at 70MPH. At 70MPH I am at about 1900RPM and the cam smooths out at 1600RPM. My concern with the 704 it would still be too ruff at highway speed. Mine is a 428 bored 40 over (435). Here is an old video from this spring when I finally got it started. I guess I should get a new one since the car is done. The sound quality from the back is not real good, the video kind of muffled the exhaust sound.
https://www.youtube.com/watch?v=qM-5...ature=youtu.be Here is the car since it was finished.
1969 428 Tremec 5 Speed U.S. Army Retired Retired Helicopter Pilot Last edited by highrisk; 11-14-2017 at 01:24 PM. |
Highrisk
I can’t make your link work and I’m dying to hear it!
Yeah, I have had that problem before, try this one https://www.youtube.com/watch?v=D1eSl8nEZHQ
Dale
1969 428 Tremec 5 Speed U.S. Army Retired Retired Helicopter Pilot |
Here's a sound clip of the 704 Voodoo in a 10.8:1 iron headed 428.
https://www.youtube.com/watch?v=bO9SShvaKUo
