Old 09-10-2022, 12:53 PM
tom s tom s is online now
Have run them for years with a pair of 750 AFBs.Dont race anymore so really no issue at 3000 RPM max.Tom
Old 09-10-2022, 02:49 PM
mchell's Avatar
mchell mchell is offline
Originally Posted by scott70 View Post
I finally took the car to the track last night. Was very surprised to see the fuel pressure gauge not go below 5.9 to 6 psi at WOT. Made a couple of highway pulls on the way there,,,same thing, Im assuming the new gauge is accurate. Warmed up it idles between 7 and 7.5 psi. I guess the old carter HP pump, is doing ok.
What did it run?
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 09-10-2022, 03:11 PM
scott70's Avatar
scott70 scott70 is offline
The usual,,, can't 60 ft. with street ties and 2.20 first gear muncie and 3.31 rear. 8.70 @ 87 mph with 2.32 60 ft. Try to leave too hard and it blows the tires away and then it's over. It's a dance. I could try some sort of sticky tires but I don't want to break something....just run test and tune playing. If it had a auto I'd be well into the 7's. 60 ft is hurting my mph also.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 09-10-2022, 03:33 PM
scott70's Avatar
I did 2 runs and then took out the DA secondary rods and replaced them with CE and the next 2 runs it picked up a little mph so it liked the rods so the y are staying in. It was humid out so the air wasn't great.
Old 09-10-2022, 03:35 PM
Formulajones's Avatar
Formulajones Formulajones is online now
Yeah a stick with a 2.20 1st gear and 3.31's isn't going to set the world on fire at the stop lights. Really hard to get that to 60 foot.
Still fun though, that's what it's all about
https://youtu.be/XqEydRRRwqE
Old 09-12-2022, 09:11 AM
mchell's Avatar
10/4….thanks for sharing
Yeah…Stick cars Always MPH higher than an auto car ….
Old 09-12-2022, 09:23 AM
scott70's Avatar
The TKX trans would be nice,,,better gearing for take offs and a OD for highway cruising. Right now I turn 3k at 70mph. It's got its original m21 still in it.
Old 09-13-2022, 09:25 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
X2 really good mph for the 1/8 but your et is is over a second off.
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 09-13-2022, 06:48 PM
scott70's Avatar
Thanks and I believe the current mph is not showing what it could do. Its wasting alot of momentum in that 1st gear. From past cars ive run as comparison if the car had a better 1oo ft from sticky tires and a tkx ,.M20 or a auto trans the mph would be atleast 90 mph.
