#101
How are you fixing the water cross over miss match to the water pump?
Street/strip 1969 TA clone. Back halfed. 3300lbs. Twin turbo LSX 387cu. JW glide. Holley Dominator EFI. E85. Street driven. https://www.facebook.com/photo.php?f...type=1&theater |
#102
It looks like they are plugged to me. A lot of people just plug them so they don't have to worry about a leak.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4. |
#103
If I can ask -- Why such a large injector ??
#104
The injectors were sized for 2200+HP.
#105
Was that based on a specific fixed fuel pressure -- or boost referenced regulator ?
#106
Specific Fuel Pressure I believe.
#107
If you have a PROPER regulator, when you have 1 psi of boost you will have 66 psi control pressure, but the injector will still see an actual 65 psi across the injector. When you have 10 psi of boost you will have 75 psi control pressure, and the injector will still see an actual 65 psi across the injector. When you have 30 psi of boost you will have 95 psi control pressure, and the injector will still see an actual 65 psi across the injector. This is called a 1 to 1 Boost Referencing Regulator which is what you ALWAYS want. Otherwise you are constantly chasing the air/fuel ratio on the engine due to the boost pressure offset. Aeromotive makes a very nice regulator (with the proper flow rate) that does this. Steve Morris Dyno has a proper fuel pump and regulator to provide 3000 hp of fuel at the correct injector pressure to the engine. Tom Vaught
#108
Tony refuses to use a thermostat bypass on any of his engines. I asked him to mill it for matching, but looks like he didnt. We simply mill it down on both sides so it matches up. It is naturally up due to the raised intake ports 5/8 inches.
Lynn McCarty dba/McCarty Racing www.RamAirV.com lmc3470@aol.com www.ChemicalManagementIndiana.com 317-260-3486 |
#109
That motor looks beautiful Lynn!
#110
Looking at your stuff Lynn, I think that when I am done with my current BBC this is the way I will go. Insane amount of power yet be streetable...thats the way I like it
#111
Thank you Engo, we are hoping to give people who have given up and gone BBC a reason to come back to Pontiacs.
#112
Havent had a bypass on my street engines since early 80's.
#113
the boost ref regulator is the right way - as far as a "street" engine - I see overheating being an issue --
#114
With EFI you can have several maps. A docile street map with about 13-1500hp and run it on E85 or maybe even pump gas. Then another full tilt racemap for the track, run it on race gas or methanol. Guys are doing it around here.
#115
The 69bird will have a 25.3 cert, will it be a street car or streetable?
We haven't dynoed it yet, as we still have a few things to work out. I will be using a boost referenced fuel regulator and most likely a belt driven fuel pump. I do have an extra-large custom aluminum radiator with 2 fans. Anyone sell a good bolt-on kit mech fuel pump setup for a Pontiac? I appreciate everyone feedback, positive or negative. The goal here, like Lynn stated above is to give diehard Pontiac guys who have switched to Chevy a reason to come back. Last edited by RAIV-Z; 12-09-2011 at 08:59 PM. Reason: typo |
#116
I was thinking about how you could bolt the fuel pump to a engine with a timing cover. I took my pump off my motor plate tonight and lined it up on another engine I have on a stand. It looks like if you built a plate to use as a fuel pump block off that had another plate welded onto the edge, you could mount the pump to it. It would need a small brace behind it but I think it would look good and be down far enough to stay out of the way. I had waterman sell me a BBC mount and told them to make me a deal and keep rear mount. They just sent me the fuel pump mount, hardware and standoff's. Or you could do this and keep the cell in the back. Looks like a nice package for the street. http://www.watermanracing.com/Pages/fuelpump25.html |
#117
The Butler/Quillen Team have a Belt Driven Fuel Pump on their engine.
Take a look at the install on that deal. Also talk to John Welter and Mike Cooper. Tom Vaught
#118
We are cam driven not belt driven. Made the switch last winter when we upgraded fuel pumps and installed the alternator.
TQ |
#119
Merry Christmas Travis --
#120
You too, Curt!
