Old 08-02-2023, 07:41 AM
firechickenman's Avatar
firechickenman firechickenman is offline
Default More Carnage From Norwalk
I saw Tim's post about his engine failure and thought I'd share mine too. I think it's odd how similar the builds and failures are. Mine was during Saturday's first round of eliminations (my 8th pass of the weekend) at about 1200 ft. The car had been very consistent and even on it's last pass the 1000 ft time was within a couple hundredths of the rest. The crank broke into 3 pieces with the 5-6 pin detached. 2 broken pistons and another damaged slightly, 2 bent rods, #5 bore is cracked, #3 main cap is broken and transmission bell housing broken. Luckily the Canton oil pan contained it all so no fluids got on the track or under my tires.
In car video: https://youtu.be/N3d1AGPM9Ko
ID:	617255   Click image for larger version
ID:	617256   Click image for larger version
ID:	617257   Click image for larger version
ID:	617258   Click image for larger version
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 08-02-2023, 07:43 AM
More pics
ID:	617260   Click image for larger version
ID:	617261   Click image for larger version
ID:	617262   Click image for larger version
ID:	617263   Click image for larger version
'68 Firebird
Old 08-02-2023, 07:46 AM
Gary H's Avatar
Gary H Gary H is offline
Sorry for the failure. Cast crank?
Old 08-02-2023, 07:47 AM
Last pics
ID:	617270   Click image for larger version
ID:	617271   Click image for larger version
ID:	617272   Click image for larger version
ID:	617273   Click image for larger version
'68 Firebird
Old 08-02-2023, 07:50 AM
Yes, I forgot to add that. Factory N crank that I have raced since 2013 and it was in a race build before that. I now know it should have been cycled out for a forged crank....
'68 Firebird
The Following User Says Thank You to firechickenman For This Useful Post:
Old 08-02-2023, 07:54 AM
Don 79 TA Don 79 TA is offline
OUCH, my gawd at todays prices, even my wallet is saying ouch just by me seeing these photos
as long as you're safe, i guess all is good
if there is a plus side... now can build something better? at least that was my motto when i was into my jetskis
i'd love to do another engine for the car, but OMG prices and the time it now takes
i don't know how people can still do this with day to day living costs so high
best of luck and i feel your pain
Old 08-02-2023, 08:15 AM
Half-Inch Stud's Avatar
Thin wall pins? What is the pin dia and wall thickness?
Old 08-02-2023, 08:24 AM
72projectbird's Avatar
Jeez, time to jack up the carburetor and roll another engine under it. How are the heads? Did they take a total ass whooping, or are they salvageable?
I'm surprised that pan didn't puncture. It deserves a spot on the wall for its outstanding service
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 08-02-2023, 08:30 AM
.980" dia. wall thickness is .150". They are the JE pins that came with my SRP pistons.
'68 Firebird
Old 08-02-2023, 08:54 AM
mgarblik mgarblik is offline
First, sorry for all that damage, hate to see that. Have you had a chance to look carefully from the #2 and #3 main oil feeds up to the cam bearings? Do you see a long crack in the block in either location?. That could be a clue as to what happened.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
Old 08-02-2023, 10:11 AM
Thanks...it's going to sting a little but it will be back bigger, better, stronger, lighter and hopefully faster!
'68 Firebird
Old 08-02-2023, 10:12 AM
Jay S's Avatar
Jay S Jay S is offline
Sorry Greg, that stinks, wow running at 1200 feet would probably test anything I have too., I have never came close to running in air like that. I’m impressed you even captured the crank breaking on that video. Looked to me like it all went at once the way it separated at the crank. I imagine that was partly do to the power and RPMs it was making. I don’t think there was any catching that on an inspection, kind of doubt it was showing any stress cracks, the photo’s appear it went in a big way!
Old 08-02-2023, 10:14 AM
Heads are good except for a few bent valves. It's past time to upgrade the valves anyway. I'm torn between trying to fix the pan or not...new one is $400 now!
'68 Firebird
Old 08-02-2023, 10:16 AM
That was one of the first things I looked at. No cracks from the mains to cam tunnel. I have another 455 block that is cracked like that up 2 and 4.
'68 Firebird
Old 08-02-2023, 10:46 AM
I'd personally hammer and dolly it back to shape and run it. Getting away with a few bent valves is the best case scenario. So basically all the damage was concentrated to the short block, which still sucks, but the top end survived which is good.
1987 Grand National
Old 08-02-2023, 11:50 AM
steve25 steve25 is offline
It's amazing how when at high rpm if the motor stops spinning in less then a blink of a the Bell housings Break like that.
I have seen it a few times before.
Old 08-02-2023, 01:19 PM
That 1200 ft was how far down the track I was when it happened, the DA was 2964 according to Norwalk's track App. I try to get all my runs on video. You never know what you might capture. I've gotten some really cool videos of other cars over the years.
'68 Firebird
Old 08-02-2023, 01:55 PM
Tim Corcoran's Avatar
Firechicken
You know that transmission can be easily fixed and not expensive either. I broke one like that a while back and I'm no running that same trans. Interesting how similar our builds were mine had J&E pistons and a 1050 Dominator same as you. Except yours's was a few .10's faster.
Tim Corcoran
Old 08-02-2023, 02:48 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Never a good thing when a crank lets go but you have put up some impressive #s with a crank that has been in service for over 10 years. At least that is some consolation amid the pain. Hope you can recover with an even better combo.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet.
Old 08-02-2023, 03:44 PM
Best way (if internals are good) is put an Ultra-Bell bellhousing on it. SFI rated anyway and usually need one. The whole bellhousing area is cut off.
