Old 12-31-2023, 10:44 PM
Nyairguard's Avatar
Nyairguard Nyairguard is offline
Default rally II paint fyi
this may help someone out here, bought a paint kit online stated a perfect match?? who knows Im building a driver,, may have been mentioned before on the site before but this is what was sent
stencil kit
seymour
2 cans metallic nickle 98-17
1 can cast iron gray 11-48
The Following 2 Users Say Thank You to Nyairguard For This Useful Post:
Old 01-01-2024, 02:52 AM
grivera's Avatar
grivera grivera is offline
Thanks- where did you buy the kit?
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 01-01-2024, 09:52 AM
Nyairguard's Avatar
fleabay inline-tube
Old 01-01-2024, 10:13 AM
Red80TA Red80TA is offline
Inline-Tube have some decent products. But you have to do your own research, their own listings and what models they fit and why are mythical.
The Following 2 Users Say Thank You to Red80TA For This Useful Post:
Old 01-01-2024, 10:50 AM
grivera's Avatar
Originally Posted by Nyairguard View Post
fleabay inline-tube
Thanks - keep us posted with pics
Will Rivera
Old 01-01-2024, 01:12 PM
Paint deal in rally iis should do well if you pick a paint that is hard to hirt with a screwdriver strike; like non-sanding gray primer followed by machinery gray Paint. I think the paint melts into the primer for a strong surface.
Had great success with powdercraft doing my rally iis when they were a startup. Now i wonder if they exist, or do rims anymore.
Key trait for rally ii success: SOMEHOW prep/fill the center plate to rim gap, so that rust doesn't start and creep out. Inside of rim is a weld but outside is a tnagential gap that harbors moisture for rust.
Old 01-31-2024, 11:03 PM
Nyairguard's Avatar
We’ll finished the 60 bucks make over of my wheels ,, I like the looks of them
Old 01-31-2024, 11:05 PM
Nyairguard's Avatar
Old 02-01-2024, 12:12 AM
grivera's Avatar
They look great
Will Rivera
Old 02-02-2024, 03:39 PM
RocktimusPryme's Avatar
I did a similar deal a while back. My take was that the paint was an excellent match, but the stencil kit was trash. The triangle shapes flat out didn’t match the wheels.
Old 02-04-2024, 08:25 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Mine needed a little touch-up on the masking also for a good outcome. Factory painted wheels were far from perfect though.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 03-20-2024, 09:49 AM
grivera's Avatar
OP - how is the paint holding up?
Will Rivera
Old 03-20-2024, 11:19 AM
Tempest's Avatar
Tempest Tempest is offline
looks good Nyairguard
I have never liked the stencils.
Here are mine, sandblasted and epoxy primed (white) ,
then sprayed silver
the masked and sprayed grey
than a satin clear coat
.... and add some custom centers
ID:	630669   Click image for larger version
ID:	630670   Click image for larger version
ID:	630671   Click image for larger version
ID:	630672   Click image for larger version
Name:	wheel centre.jpg
Old 03-20-2024, 11:31 AM
Nyairguard's Avatar
Love those centers , dealing with weather stripping doors and t-top surrounds.. this is my first 2nd gen and out of the eight cars I restored this weather stripping kicking my arse tried metro and Fairchild and both fit poorly
Old 03-20-2024, 11:57 AM
grivera's Avatar
Tempest - that center cap is awesome!
Wheels look great - What brand and paint code did you use?
Will Rivera
Old 03-20-2024, 01:08 PM
Tempest's Avatar
just used Rustoleum ?? I think. the silver is easy, but I find that the grey can't be too dark, or they don't look right (to me) It was just an off the shelf automotive paint, not sure of name/code? sorry.
the centers were made on a 3D printer by a friend of mine. (and I put many coats of clear on)
I am hoping they look good on my 58 Pontiac Wagon (work in progress)
ID:	630697   Click image for larger version
The Following User Says Thank You to Tempest For This Useful Post:
