Old 07-03-2012, 08:03 PM
65Mark 65Mark is offline
Default 64 reverb switch
Is the 64 switch different than the 65-67? The restoration book shows a switch on the lower dash to the right of the steering column, and 65-7 in the usual spot on the instrument panel. I don't remember from 40 years ago. Was the switch in 64 ever put on the instrument panel? Thanks!
Edit: It is the defogger switch we need, not the reverb... Thanks Bob!
Old 07-03-2012, 08:46 PM
BOB VIDAN BOB VIDAN is offline
The physical switch is the same 64 - 67, but 64 - 65 bezel and knob are different than 66 - 67. 64 - 65 switch mounts at the top of the dash bezel, same as 66 - 67. Only switch that mounts in the lower is 64 - 65 is power top and defogger.
Old 07-03-2012, 09:00 PM
Crap....
Thanks Bob. It was the defogger that was in question. I'm getting rummy here. It's the defogger switch that we need then. We have a 66 switch. We've been going around in circles trying to get this ready for the Pontiac Picnic in the Park on the 14th in Enumclaw, I don't think we'll make it. Do you have a switch? Steph is going to look but he didn't think so.
Old 07-04-2012, 12:17 AM
JAKE 64 JAKE 64 is offline
The defogger switch for the 1964 sits in a 1 in. x 1.5 in. opening in the dash. This opening is below the windshield wiper control knob. The switch is moved up or down to activate vs. the rotating switch used in later models. The first two pictures below show two rectangular switches for the '64, and one switch used after '65.
I also included a couple of pictures of the defogger. Note the difference in the motor housings for the '64 (two pictured) and the housing used in later models. The wire connector is different for the '64, as it pushes onto a brass pin on the motor housing.
The Defogging Blower Gasket (Part No. 9776181 shown with tape measure - gasket in background is for a later model) measures 1/2 in. thick, and is made of high density foam rubber. Surprisingly, for all of the years this sat in the back window, the gasket is still rather supple.
Hope this helps.
Name:	1964 Rear Window Defogger 001.jpg
ID:	289859   Click image for larger version
Name:	1964 Rear Window Defogger 002.jpg
ID:	289860   Click image for larger version
Name:	1964 Rear Window Defogger 003.jpg
ID:	289861   Click image for larger version
Name:	1964 Rear Window Defogger 004.jpg
Old 07-04-2012, 09:13 AM
RA1John RA1John is offline
64 Tempest & 64 Full-size Reverb Switch comparison...
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
Old 07-04-2012, 02:56 PM
Thanks guys. I appreciate the help. On to the quest for a defogger switch.
Old 07-04-2012, 08:30 PM
64woodwheel's Avatar
64woodwheel 64woodwheel is offline
That would be the switch for a dealer installed power antenna.
