Old 06-14-2022, 06:48 PM
pont406's Avatar
pont406 pont406 is offline
Question Valve question
Will the stock exhaust valves from a 1971 #96 head work in a stock 1967 670 Head ?
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
Old 06-14-2022, 07:05 PM
John Milner's Avatar
John Milner John Milner is offline
No, if stock length, the #96 heads will have valves that will be too short for the #670’s.
The Following 2 Users Say Thank You to John Milner For This Useful Post:
Old 06-14-2022, 07:40 PM
25stevem's Avatar
25stevem 25stevem is offline
The 670 heads need a 5.095” lenght and the other a 4.980”, so like posted above nope.
But the other way around will if you needed greater installed height for stout valve springs.
PS,
In a real pinch you could since it’s only a .115” different, but you would then have to cut the spring seats by that much which is doable, and run the same amount shorter push rods, so at that point push rods for a pre 67 motor I believe would work.
I do stuff for reasons.
The Following 2 Users Say Thank You to 25stevem For This Useful Post:
Old 06-16-2022, 11:05 PM
67Fbird's Avatar
67Fbird 67Fbird is offline
you CAN tweek stuff all over the place. As a direct "awap" = NO
Any .343 stem valve COULD be used as long as you understand what happens when you move from the OEM length.
