1971 Firebird Drag Car $ 28' Enclosed Trailer
For Sale: 1971 Firebird Drag Car.
Engine Built by: Ceralli Competition Engines of Patterson NJ & AllPontiac.com of VA Engine Dyno: 862hp @ 6800rpm Torque: 751 @ 5400rpm Max RPM: 7500 Block: Aftermarket All Pontiac IAII Bore: 4.350” Stroke: 4.500” Rod Length: 6.800” Displacement: 535.0 cubic-in Compression Ratio: 14.00:1 Rods: Scat h-beam w/APR 2000 Pistons: JE Custom Flat Top Weight: 450 grams Crankshaft: Scat Forged knife edged, polished and balanced with 2.200 rod & 3.000 main journals straight shot oil CAM: LSM Engineering Custom Grind Solid Roller Intake Duration: 285 Exhaust Duration: 294 Fire Order: 1-8-7-2-6-5-4-3 Intake Lift @ cam: 485 Exhaust Lift @ cam: 450 CL: 114.00 Heads: All Pontiac Tiger 64cc Intake port: 310cc Intake Flow: 420cfm Intake Valve: 2.300” Exhaust Valve: 1.800” Exhaust Port: 17 Deg Rockers: Jesel Shaft System 1.80 ratio Intake: All Pontiac Tiger port matched Carburetor: 1250cfm AED Dominator Transmission: JW Powerglide: 1.80 Convertor: Custom 5500 Stall 9” Pro Tree trans Break Rear End: Moser Engineering Fab 9 Axels: 40 spline Moser Ring Gear: 4.29 Full Spool 3rd Member: Mosier Bolt thru Aluminum Suspension: Caltrac bars Leaf Spring: Caltrac split mono Car has 4 passes on it. No trans break lauches as of yet. Best et at 4800' elevation was 10.02 at 136 mph. Trailer is 2001 Haulmark 28' enclosed. New 16" LT truck tires, floor is Hurculined, and diamond plate runners. Can email pics of car and dyno sheets along with documentation. Trailer is off sight but can get pics of serious. Come out to Vegas, have a good time, buy a car and trailer it home. $23,000 for it all. Call Chris 702-656-1220. |
A few pics of the 71 Firebird.
Furloghed and forced to sell. Make a reasonable offer. Will send additional pictures/info upon request.
A few more photos
... how much does the car weigh ? ...
I haven't had it on the scales yet. I would guess in the neighbor hood of 3200.
Is this car sold?
I still have the car and trailer for sale.
Trailer
Have any pics of the trailer
I can get pics but will be later this weekend after the NHRA races
Trailer pics
more trailer pics, last one shows damage to the outside skin, but its only cosmetic.
Willing to entertain offers or trades for driver quality 70 thru 79 bird. Update on last outing this year (April) 9.955 @ 132.58 and 9.957 @ 136.03, still more left in it, no t-brake launches, and leaving lazy at 1500 rpm. Trying to work up slowly, 1.527 60' & 6.04 in 1/8 @ 110.
Car & trailer still for sale. I will consider serious cash offers/trades. Best to call 702-656-1220 as I don't get on site as often as I used too. Chris. Located Las Vegas
