Old 06-27-2021, 05:23 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
Default Pattern on Valve Tip Opinion
Hi everyone, we are measuring pushrod length today, we made a hydraulic lifter solid by stacking it with washer, we then turned the engine until lifter was on back side of lobe, adjusted stock factory length pushrod to zero lash, tightened the poly lock, then turned the engine two full revolutions and this is the pattern we got. Looks awful wide to me, but we have never measured pushrod length using factory stamped steel rockers like this build will use, its always been full roller rockers in our past builds. Is this pattern normal for a stamped steel rocker? If so, how does it look? Heads are factory 6x4, just barely cleaned up to make sure they were flat, no more than .010" taken off deck, stock length 4.98" Ferra valves, Crower 68404 springs are set up at 1.550". Camshaft is a Voodoo 704.
ID:	568891   Click image for larger version
ID:	568892   Click image for larger version
1978 Trans Am
Pump Gas 461 Stroker
Old 06-27-2021, 05:26 PM
For got to mentioned above, we will be ordering the .116" wall pushrods from Butler just as soon as we know for sure the length we need. We were just using the factory length pushrod to initially measure it with for a starting point.
1978 Trans Am
Old 06-27-2021, 06:33 PM
tempest1964's Avatar
Did you look up the Straub method to set your pushrod length?
The Following User Says Thank You to tempest1964 For This Useful Post:
Old 06-27-2021, 06:36 PM
Originally Posted by tempest1964 View Post
Did you look up the Strauss method to set your pushrod length?
I did, but the method they show is using a full roller rocker, which is next to impossible to figure out when using a stock stamped style rocker, do to no Trunion and roller wheel axle centerline to go off of.
1978 Trans Am
Old 06-27-2021, 06:46 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Stamped steel rockers do swipe a bit wider than a roller tip variety but I've never had any quite that wide.
Did you vary your adjustable pushrod in both directions to see if it tightened up the pattern some?.....
Old 06-27-2021, 06:58 PM
Thanks Cliff, we haven't tried the adjustable pushrod yet, we just did it with a factory pushrod first to see where it was at, and this was the result. We will check it with the adjustable pushrod and report back.
1978 Trans Am
Old 06-27-2021, 07:23 PM
Here is the pattern with the adjustable pushrod at 9.200"
1978 Trans Am
Old 06-27-2021, 07:26 PM
pastry_chef's Avatar
Looks you need a longer pushrod from your first post. Not the second.
Try this:
Set the lifter on the base circle of the cam. Now set the adjustable pushrod in place and adjust the rocker until there is zero lash. Now lightly rub the rocker across the valve tip to establish a witness mark on the valve tip. Inspect the position of the mark and re-adjust the pushrod length until the witness mark is roughly 1/3rd of the distance toward the intake side from centerline.
Another reference, about 2/3 of peak lift the mark should be about center of the valve tip.
The Following User Says Thank You to pastry_chef For This Useful Post:
Old 06-27-2021, 07:29 PM
steve25 steve25 is online now
I hope you had the tops of the valve guides topped for positive seals because this is a picture of the not enough retainer to guide clearance you will have at only .500” lift without the guides topped.
This shown is with a stock length exh valve and a stock retainer like I see your using, and this is on a 6X head also.
Old 06-27-2021, 07:34 PM
I hope you had the tops of the valve guides topped for positive seals because this is a picture of the not enough retainer to guide clearance you will have at only .500” lift!
This shown is with a stock length exh valve and a stock retainer like I see your using on a 6X head.
Thanks Steve, we built the heads, and took some off the retainers and cut the guides down for Positive seals, so we made sure everything had plenty of clearance when we put them together. All of them have atleast .060" retainers to seal clearance. Thanks for the heads up though, much appreciated!
1978 Trans Am
Old 06-27-2021, 07:38 PM
Old 06-27-2021, 07:43 PM
Here is what it looks like the the pushrod adjusted to 9.100"
1978 Trans Am
Old 06-27-2021, 07:47 PM
Here is the witness mark with the lifter on the base circle, lifter at zero lash, pushrod adjusted to 9.100"
1978 Trans Am
Old 06-27-2021, 07:54 PM
Witness Mark with lifter on base circle, lifter at zero lash, pushrod adjusted to 9.150"
1978 Trans Am
Old 06-27-2021, 08:01 PM
Witness Mark with lifter on base circle, lifter at zero lash, adjustable pushrod set at 9.200"
1978 Trans Am
Old 06-27-2021, 08:02 PM
The pattern is wide even when you are not moving the rocker across the lift range.
That explains much.
Old 06-27-2021, 08:24 PM
That explains much.
Here are the two witness marks, one on the base circle, the other at 2/3 lift, both with the lifter adjusted to zero lash, and the pushrod adjusted at 9.200"... to me, the 9.200" pushrod seems to be the best so far. What do yall think?
1978 Trans Am
Old 06-27-2021, 08:46 PM
Ok, we tried one more time, this time with the pushrod adjusted to 9.250". These ARE two different marks, one with lifter on the base circle, the other mark is at 2/3 lift. Lifter was set at Zero Lash(No Lifter Preload) for both.
1978 Trans Am
Old 06-27-2021, 08:54 PM
So, reviewing and comparing all of my above pictures, am I correct in thinking that it seems that it may like the 9.200" pushrod the best, especially since .050" or so of lifter Preload still has to be added? The 9.200" witness mark above, at 2/3 lift, appears to be just a tad towards the exhaust side from the center of the valve, so I'm thinking by the time the lifter gets .050" or so of preload, it will be right in the ball park?
1978 Trans Am
Old 06-27-2021, 09:29 PM
With the photos above, I'd agree.
I think it was post 7.. full sweep of 9.2 . Getting closer than I'd like to exhaust side of valve tip.
I'm curious how 9.15 full sweep might look compared.
I do like where the 9.2 begins
