Hydraulic Roller Lifter
Does anyone manufacturer a hydraulic roller lifter with pin oiling? Found several solid rollers with oiling, but no HR's.
I think Mark at LPI has some but so far I think for aftermarket blocks only. Might check with him.
I see Crower makes than for a SB Chevy...not cheap man!
The only thing is, to use them you would have to cut the link bar, span it and reweld it I guess to work for a Pontiac.
I don't understand why they can make them for Chevy's but not for Pontiac. I mean, I understand Chevy's are more popular, but they already have the setup to do it, so why not just do it on all of them. Especially when Chevy and Pontiac lifters are the same size. Typical after market thinking, let's give all the good sh*t to the Chevy boys and screw the Pontiac people. After all, no-one builds Pontiac's anymore, right?
Paul to run a roller in a 409 Chevy the Comp Chevy lifters have to have the link replaced by SB Ford links purchased separately, and they won't take back the Chevy links.
Most applications won't see a problem with non oiling bearings unless they get into radical profiles, springs and/or poor oiling system mods. Lotta splash and drain down with an open valley to help keep the cam lubed. |
Run them exclusively. No issues. 66bonne still has the same C.C. hyd rollers in his current 496 combo from his last combo he ran for years. Has over 20,000 miles plus lots of racing time. I ran them in my own 260plus@.050 with .650 lift cams. Even had them running to 7000 rpm on nitrous. LOL. Install them with all my CC hyd roller std and custom profiles. Lot has to do with adjustment, type of oil, oil pressure, spring pressure with cam profile, etc.
Most new vehicles come with roller cams - do any of these engines use lifters with pin oiling?
A/O HRL's
Yes we do sell a hydraulic roller lifter that has axle oiling. We also sell a non-axle oiling limited plunger travel hydraulic roller lifter.
The reason why we have two lifters is due to the design of the cam tunnel in a stock block versus the two aftermarket blocks. The tangent point of the cam tunnel in a stock block is further from the lifter bore meaning the lifter bore is shorter in length. This shorter length dictates where the oil hole is located to provide a path to the axle and NRB in the lifter. We can as I have mentioned before we can create an axle oiling option lifter for the stock blocks but the cost is $1900.00 per set. We look at it with our products as follows: Lifter #1 will fit stock blocks and aftermarket blocks W/O axle oiling good for 600 lbs. open pressure and 6500 rpm. For us that is what we expect from a stock block under boost conditions with our oiling system and main bearing system design parameters. Lifter #2 will only fit the aftermarket blocks and is good for 1,000 lbs. open pressure and will easily go to 7500 rpm. Again for our boost build conditions this is more than enough lifter to make big Hp. Along with our new 3 point oiling, grooved cam bearings we see no reason not to run maintenance free (Like the OEM’s) hydraulic roller systems. This is the 21st century…LOL We will be running a special on the standard lifter For March and April. Normally they retail for $599.99 a set we will be offering them for $509.99 a set. The axle oiling units are more due to the cost of making 10 sets at a time. If the demand goes up then the price will go down. Please contact us for pricing. We also offer a complete service for design of N/A and boosted hydraulic roller camshaft profiles. We will be testing a set of the axle oiling lifters and our newest boost profile in the next couple weeks. If you have any questions please give us a call or drop us an email. |
Sorry L4S,
To answer your direct question I believe to the best of my knowledge most of the OEM's do not use an axle oiling lifter. Most due to the fact of production cost and the environment that they are designed for...passenger car for 100K miles and 5800 rpm. The Corvette might have an axle oiling lifter as well as the Z-28 but I do not know for certain. |
Plus OEM vehicles with hyd. roller lifters only run about 70-80 lbs. on the seat and maybe 200 lbs. open. Doesn't take much to make them live. Plus cam lobe profiles are very tame on them.
Ken - Are you familiar with the Comp Hyd Rollers that are the'new' design which have a 'D' in the part number? I've heard they have corrected a tolerance issue in them and run quieter, though only have heard this by mouth, haven't looked further into it. .
Thanks! |
