Old 07-25-2023, 08:25 AM
Harold Washington Harold Washington is offline
Default master cylinder
What's a good master cylinder for disc /disc no booster
how455
Old 07-25-2023, 02:29 PM
More detail about the car please?
Old 07-25-2023, 06:25 PM
MatthewKlein MatthewKlein is offline
I used an aluminum master from a 83-94 s10
MCA390320
If I recall the lines are reversed: my original master cylinder front port went to the front brakes and this was opposite.
Old 07-26-2023, 09:59 AM
Skip Fix Skip Fix is online now
Some of the choices will be affected by caliper piston size, pedal ratio and how you like brakes to "feel". Bigger pistons need more fluid to move them so a bigger piston but that increases foot pressure to get the same line pressure.
15/16-1&1/8' seem to be common for most folks, or the equivalent metric piston sizes. Too small and there is move pedal travel to move the same volume.
I have roughly a 15/16" on my Wilwood Dynalite front/D154 rear caliper setup on the 79 Camaro/IA car. Started with a 1 &1/16 but the pedal effort the firewall was flexing some.
Strange has a couple of Mopar style both larger than 1" but you can cross reference different Mopars (minivans etc)in different sizes-what i did. bolt spacing slightly different than GM but a die grinder makes them work
