Old 04-02-2015, 02:33 PM
TransAmRAFormula's Avatar
TransAmRAFormula TransAmRAFormula is offline
Default DRY SUMP
I was just wondering if there is any way to convert a Pontiac motor for dry sump oiling.
1972 Formula 400 4-speed, Revere Silver with black interior.
1996 Trans Am WS6 6-speed, Black with camel leather.
2015 GMC Sierra 2500 HD Denali, Black
2010 Trans Am Conversion, 6-speed with LS3
1995 Comp T/A #29, hard top manual
Old 04-02-2015, 03:08 PM
SD73's Avatar
SD73 SD73 is offline
You don't have an SD by chance? Those are setup for it, but finding the parts now would probably be a task. Not sure if anyone makes a conversion for the non SD blocks.
Old 04-02-2015, 04:13 PM
I have a 455 but it's not a Super Duty block unfortunately
Old 04-02-2015, 06:24 PM
Try looking at some dry sump setups for race cars, roundy-round cars use them a lot.
(try the local circle track)
The 'problem' would be deciding where to mount the pump and tank.
Probably on the passenger side if you have alternator and PS already.
Then you would need a dry sump pan or at least at some bungs in yours to evacuate the pan.
Probably not all that hard just takes up some room in the front end area.
(and another pulley to run sump pump)
Old 04-02-2015, 09:14 PM
Thanks! I am going to see what I can find.
