JB-Weld for evrything but head gaskets
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct Last edited by Half-Inch Stud; 01-09-2019 at 08:27 PM. |
Well that was interesting. JB weld is some pretty tuff stuff. Yeah it failed the head gasket test, but then again, who in their right mind uses JB weld or any glue as a head gasket.
Copper hoops and both deck and block surface wiped with silicone grease may have allowed movement and tolerate differing expansion rates.
I suspect copper o rings around bores only, with or without receiver grooves could seal quite well using "Right stuff" around water passages and along valley edge. Alternately steel rings in the top of bore directly to head deck and no gasket, seals combustion very well . Typically done with dry deck. That said, if not dry decked products such as "Right Stuff" would be quite capable of sealing the water passages and valley/deck edge.(It's flexible enough to not lose seal with expansion differences.) |
