Old 04-16-2007, 01:53 PM
PONTIAC DUDE's Avatar
Question QA-1 Front coilovers:
Anyone running QA-1 Front coilovers in the stock control arm pockets. The ones that fit up into the frame and on top of the 12 way adjustable shock that mounts to the lower arm. The spring looks like a reversed Beehive setup.
Mainly interested in the race or street/strip application for a 2nd Gen Firebird but see they make em for GTO's etc.
Results?
Good - Bad?
Info?
Old 04-16-2007, 02:20 PM
68 GOATHERDER 68 GOATHERDER is offline
I have the QA-1 R front coilovers in my 68 goat. I just ordered different springs because of a weight issue. I strongly recommend weighing the front end before ordering them. The mail order companies do not list the specialty spring rates. They list them on their website WWW.QA1.NET The install was easy.
Old 04-16-2007, 03:27 PM
Ron H's Avatar
Ron H Ron H is offline
www.autofabracecars.com is who I ordered mine from. They have the best prices I found. Good people, quick shipping.
The nice thing about them is the ability to adjust the ride height. As noted by Goatherder, weigh the front end and order the correct spring rate. Adjusting the ride height does not change the spring rate.
They have tons of adjustability for launch etc. Bolt right in.
68 Firebird
Are you running with the wind or breaking it?
Old 04-16-2007, 05:49 PM
steve's Avatar
steve steve is offline
ditto the front end weigh. i did not realize how much weight i had shaved from the front when i ordered mine.....they are way stiff. no bounce back after you push down on the front.
what LBS. are yours rated at RON H....?
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-Moser rear-Dougs Headers....
Old 04-16-2007, 11:52 PM
dirty joe dirty joe is offline
i have them on my 79 grand prix. extremely easy install. and yes, like a behive. the adjusting knob is easy to get to. the height adjustment, a lil hard, but way way way easier than having to pull out and cut springs. member on here-BrandX, a good buddy of mine from around here will probably chime in. he will have some results here pretty quick from his 72 lemans (from moroso trick and 3 way adjustables, to coil-overs).
i love racing at the track
Old 04-17-2007, 01:08 AM
cjaghblb cjaghblb is offline
Put them in my 64 A Body, Bought them from Dick Miller Racing and he recommended against the coil-overs for drag racing since the launch weight transfer is better using traditional coils/shocks but I was commited to the coil-overs for the ride height I was after. I am real happy with them since it was an easy bolt-in and I no long have to deal with compressing the spring each time I pull the front end apart.
Old 04-17-2007, 10:35 AM
David Holmberg's Avatar
Randy put 'em on the S10 over the winter and loves 'em.
Old 04-17-2007, 03:19 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I have seen some reinforcement plates used for the bottom of the control arms since they use the shock mount thin area to support the car.
I have set just haven't installed them yet.
Old 04-17-2007, 03:26 PM
Ron H's Avatar
I bought the 350 lbs rated RGMP-1350 race series. But I was intending and now have a full fiberglass front end. Plus aluminum heads etc. I may have to drop to the 250 lbs spring, hopefully i can get finished assembling this week and after break in get to some scales to check my new weight.
The 1450 series would be the ones to use on a cast head full steel car.
68 Firebird
Old 04-17-2007, 05:06 PM
also, another buddy here put them on his g-body malibu. he picked up a tenth changin from stock springs and 3 way adjustables to these coil-overs.
Old 04-17-2007, 06:26 PM
SLICK1 SLICK1 is offline
Wink
Results?
Good - Bad?
Info?
Contact Jeff Kinsler, He runs that setup on his Bird! He can help with your questions.
(see it in action)
http://video.tinypic.com/player.php?v=2sbpmkm
Old 03-23-2019, 09:15 PM
74Bluebird 74Bluebird is offline
Just put them in my 74. Mine is for street use only , no race, but very satisfied so far. Wanted to be able to adjust the ride height mainly. The car rides better than it did on coil springs.
Old 03-24-2019, 08:40 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Damn that was 12 years ago!
I got all excited thinking that Kenny was back.
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
Old 03-24-2019, 11:37 AM
Stan Weiss's Avatar
He does post over on Yellow Bullet
https://www.yellowbullet.com/forum/s....php?t=2569091
Stan
Pontiac Pump Gas List
Old 03-24-2019, 12:18 PM
76TA462 76TA462 is offline
I am running their coil-overs (A225-550R) and tubular uppers and lowers. Used the lowers because the pockets on my OEM were showing some weakness and QA1 tach had concerns with that. 76 TA with a somewhat lighter front only due to aluminum heads etc., so near stock. Last summer was first go with them and I am very happy with the handling results. Started with their recommended settings, but ended up doing some tweaking to get the right compression and rebound for my needs, but that was pretty easy even for a casual "mechanic" like me. Stiffer than OEM as expected, and the handling characteristics both on launch and especially cornering are better than I expected.
Old 03-26-2019, 10:54 AM
Jack you can find Ken on Facebook most anytime. . Hmmm...then again maybe you never get many friend requests?☺️
