Nice Kris. I've always liked 400s and 428s both are underrated IMO.
Congrats! nice car.
krisr,
You must be a very good tuner because 11.4 @3850 Lbs with the 400/400 is haulin! Top-end MPH shows great flow! The Total ADV is a suprise to me but i've been using iron heads exclusively. E-heads to my front?
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
Thanks guys.
HIS - Once I get it running on corn juice, I might hire the chassis dyno down the road and do some sweeps to see if I can tune the curve a bit better because at the moment it's just flat 38 from 3600-7000. Most engines i've done will respond very well with adding a few degrees or taking a few away at different RPM points to hang onto MBT. My E-Heads are the old bathtub chamber type so i'm not at all surprised that it loves timing. I just looked at the timing map again and between 3200-3600 i'm commanding 40deg at WOT. Theory was to try and yank on the converter a bit harder out of the hole as it's flashing to about 4000 but the converter i'm not touching until I get the 80e box built. Whether having my timing curve set like it is, it kind of works I think but i'll mess with at a later date. It 60's pretty good like that for a heavy thing with a tight converter!
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
Nice combo and car. My old 402" combo with early ehead chambers liked 40 degrees timing also.
Nice combo and car mate (my first musclecar was an Aussie Falcon 2 door-Mad Max type), I've always preferred the 389/400 combos-short stroke is easier on the factory blocks. Looks like you're making around 500 horse-still a lot left in that little 400 yet.
awesome numbers, love to see someone still using a true 3.75 motor. I sure love a good 400, and i love a Holden, thanks for sharing!
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components Last edited by adam woodmancy; 06-19-2019 at 11:28 AM. |
https://www.youtube.com/watch?v=5nnPU_Zw3f8
PPTTFMF
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Kris, you couldn't do multiple in tank pumps to keep from doing the cell in trunk deal? Or maybe that's your preference... I did that deal years ago and didn't really care for it. Good luck getting it properly fed whatever it takes!
kris, i will tell you that on my mild 405, with stock crank, rods, and speed pro flat tops, 1st gen e-heads and victor, 255/262 solid f.t. cam, my motor didnt show that big of an improvement on the dyno going from 93/110 mix gas hp carb to my 750 kjp methanol 4150, it made 496 ish hp and less than 500 ft lbs on gas, and 523 on alcohol with still under 500 ft lbs. i figured the torque would be where the big gain was, but it hardly moved and the hp went up around 25hp. fast forward to putting it in the car on gas, it felt like a lazy pig. it wouldnt hardly turn the 275's over on the street, i did nothing but swap carbs and fuel, and it was crisp and skating all over the place. I wouldve swore it was a completely different engine. I'll admit, it was running rich on gas which contributed to it being lazy, but i picked up 4 tenths in the 1/8th mile by changing carb and fuel. its amazing how things react in real world tests vs the dyno.
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components |
Your improvements over Gas as fuel is do to the E 85 taking up more room ( more fuel vapor) in the runners which is off setting the effect of the E heads port volume being too big for your motors cid and power band!
Beautiful car and impressive times.
I added this link to what has to be your car. https://youtu.be/a04mD93LBAg
1970 GTO 400 Atoll Blue, PS, PDB, A/C Was M20 4 speed, now has Keisler RS600 5 speed. Last edited by pontiacmark; 06-21-2019 at 08:41 PM. Reason: Added link |
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser Last edited by krisr; 06-22-2019 at 05:58 AM. |
