Old 01-05-2019, 05:35 PM
slowbird's Avatar
slowbird slowbird is offline
Default Winberg Crankshafts?
Anyone know if Winberg Crankshafts makes billet cranks for us Pontiac guys?
Old 01-05-2019, 07:43 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
Will be interesting to find out. Their site says prototype so they would make anything you could dream up. Wonder what the ULTIMATE Pontiac V8 crankshaft would be? Definitely want the added counterweights....Billet, anything else "design-wise" that one would want?? Just curious what we could dream up to have designed.
Old 01-05-2019, 09:55 PM
Steve C. Steve C. is offline
Here, design a crankshaft
http://www.epi-eng.com/piston_engine...ign_issues.htm
"People think billet is stronger than a forging, but that's not true. Billet got that reputation from back when forged aftermarket cranks weren't readily available, and billet was the only way to go for a performance crank. With a forged crank, the forging process creates an interwoven grain structure."
Crankshaft Tech - Hot Rod Network
Old information here:
Old 01-05-2019, 09:57 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
It you need a few made, I would likely go in with you.
Old 01-05-2019, 10:08 PM
Bnick166's Avatar
Anyone wanna play along and figure out what the ultimate crank would be? I took a quick look At the link above. ...a heat treated and nitride, straight shot oiling, fully counterweighted forging with a real slick finish...anything else?
Any stroke or main & bearing size more desirable than another?
Old 01-05-2019, 10:11 PM
Bnick166's Avatar
From the link you supplied..... "There is an old argument that a forged crank is superior to a billet crank because of the allegedly uninterrupted grain flow that can be obtained in the forging process. That might be true of some components, but with respect to crankshafts, the argument fails because of the large dislocations in the material that are necessary to move the crankpin and counterweight material from the center of the forging blank to the outer extremes of the part. The resulting grain structure in the typical V8 crank forging exhibits similar fractured grain properties to that of a machined billet. More than one crankshaft manufacturer has told me that there is no way that a forging from the commonly used steel alloy SAE-4340 (AMS-6414) would survive in one of today's Cup engines.
Old 01-05-2019, 10:43 PM
Maybe, and not meant to argue. But I'll suggest not apples-to-apples.
In part from a article regarding the costs of NASCAR.....
Here is where we really see the power of money. Production engines live and die by a couple of dollars, while cost is no object for racing engines. (We've heard that one Nascar engine runs about 50 grand.) The pistons, rings and wrist pins in a Cup engine cost about three times the cost of an entire production Hemi V8, reports Baer.
Then consider NASCAR's exotic (and expensive) titanium valves. The expense comes from the complex shape of the race pistons and the precise machining of their surfaces, Baer says. "You can't just knock them out on a lathe," he said. "It takes special equipment to make them."
The same goes for the crankshaft, which is made of an advanced iron alloy. Even race spark plugs are unorthodox and comparatively pricey, Baer adds. "Production spark plugs cost pennies and ours cost dollars," he says.
Old 01-05-2019, 10:55 PM
tom s tom s is online now
I called Henry Velasco a couple years ago,he makes billet cranks.In Downey CA.Tom
Old 01-05-2019, 10:59 PM
Awhile ago after 10+ years of service I had a oiling issue that led to one bearing going bad. The crankshaft LOOKED fine except upon routine inspection we found the custom Crower billet crankshaft SLIGHTLY out of spec. The machine shop started to straighten the billet crank and right away the sound ..... BING ! It cracked. Junked it and ordered a Lunati forged crank and finished the repair.
A tid bit and a story for conversation. Does it mean anything relating here, I have no clue.
Edit: I do agree that CUP engines run billet cranks. It's the cost and typical delivery time that is not apples-to-apples with the forged Pontiac cranks sitting on shelves ready to ship.
Crankshaft Tech – Crank Call
https://www.hotrod.com/articles/0710...ankshaft-tech/
Old 01-06-2019, 12:17 AM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
I have a billet Velasco crank but I also bought a Winberg for the A/Fuel Dragster and I must admit - it's Jewelry quality and was almost to pretty to use!
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
Old 01-06-2019, 02:39 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Bnick166 View Post
... Wonder what the ULTIMATE Pontiac V8 crankshaft would be?...
I don't really know. But I would investigate a configuration that could [somehow] have a retention scheme for high-strength magnesium (Electron-43) filler segments to eliminate all leading/trailing edges of counterweights- as I did with my four-banger Moldex billet (which was very tedious to do after-the-fact).
I would also look into alternatives to the normal half-moon keyway in the snout. My blown hemi V8 did well by milling the keyway full-length of the snout and using a single long key through both the timing gear and the blower pulley hub. For the four-banger (more inherent torsional vibration) I went to a single long round key to eliminate the stress risers at the corners of a square keyway- which also was a devil of a job.
Old 01-06-2019, 07:13 AM
steve25 steve25 is online now
Steve that's full on true!
A non twisted 4340 Crank is the ultimate in strength you can get!
I am not 100% sure but I think a twisted Crank and most Billets are about the same in strength?
Old 01-06-2019, 10:29 AM
slowbird's Avatar
The dragster have a pontiac in it? Got pics of the winberg crank?
Old 01-06-2019, 11:32 AM
Gary Kubisch Gary Kubisch is offline
I really always envied the fact that the Pontiac guys could get a Sonny Bryant crank.
Old 01-06-2019, 11:33 AM
Bnick166's Avatar
Discussions are meant to enlighten us on a specific subject and we all have our own opinions and schools of thought. I thought It'd be neat to poll them together and see what we could dream up and have designed so Winberg could whip one (or 10) up and maybe they would have an offering for the Pontiac V8. And not just some "run of the mill" crank available from many places...but a "kick-ass" crank that any "True Pontiac Race Engine" enthusiast would salivate over. Jack has some GREAT input...anyone else care to "dream" up a crank to submit to Winberg for pricing?
Old 01-06-2019, 12:13 PM
And the process starts with a poured metal. An ingot is basically a casting ! How and what is blended before becoming hot poured metal and the processes involved in shaping, hardening, and creating the final product is what makes the difference.
Powdered metal technology is showing possibilities and may end up being the ultimate in process for parts of the future.
Could powder based materials be blended with metal and plastics for the ultimate durability???
I think so. I've seen thin plastic metal blend materials (machine covers)that took a cut off wheel or hack saw to trim vs older version you could simply score and break off with a pocket knife. The company I worked for was using both powdered metals and powdered plastics as early as the 80's. I'm sure the technology has advanced considerably.
Composite crank and rods anyone???
Imbedded hi tech metals in equally hi tech plastics???
The OEM's seem headed this direction.
Old 01-06-2019, 12:20 PM
Bnick166's Avatar
Good points, Bruce. How do we figure that into our dream crank that we submit to Winberg?
Old 01-06-2019, 01:13 PM
Tell him to get together the scientists to develop the materials and processes.
Shouldn't cost much right ?
Perhaps the right blend of advanced epoxy resins (JB Weld? lol) and a mix of powdered metals you couldn't normally/easily melt together let alone take advantage of their own specific heat treat qualities??? Better yet you would then make it possible to have strength, cushion and lubricity where each are most needed.
Old 01-06-2019, 03:16 PM
mgarblik mgarblik is offline
Does anyone posting have an inside track with a person, owner or engineer at Winberg? I ask this because many years ago after waiting nearly 2 years for a Moldex, I talked to every crankshaft manufacturer at PRI about making Pontiac crankshafts. Winberg, I remember distinctly, poo-pooed the idea and questioned me directly why anyone would want or need a billet crankshaft for a Pontiac. After a lengthy discussion, they reluctantly said they would carve out a Pontiac crankshaft for some crazy price. (They obviously were trying to make me go away). Their stuff looks really nice, but didn't get that warm and fuzzy feeling they were at all interested in making them. Crower, on the other hand was more than willing to make any type of billet crank we needed with all types of special operations such as the 4 keyways we use on the funny car. I just have a hard time getting involved with companies that are openly condescending, eye rolling, and think you are a moron for not running a BBC, or a Hemi. If things have changed at Winberg, that's a very good thing.
Old 01-06-2019, 10:39 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Hey Mike,
I had the same experience back in 2012. I was told they would need to do 50 cranks to even consider Pontiac crankshafts to make them cost effective.
Thanks.
Calvin Hill
Hill Performance
708-250-7420
