#961
So that's a no....yet he has hit 150mph in the 1/8 in a true street legal car...and you have come close in a race car....
#962
12 mile drive?
I would run out of gas around mile 4 or 5! I have enough to go to the liquor store and back.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
#963
#964
Well you need facts first to call it. So please go back and find where I said anything negative about Dicks car. Please...
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
#965
So you're car has headlight, flashers, roll up windows, inspection , insurance, legal plates and dot tires?
#966
Headlights,tagged and insured and a drag radial tire, and mufflers.
#967
Theses types of comments from someone like you does the Pontiac community a disservice. Why don’t you jump on the “light car” bandwagon and slam the shops who prepped the HP heads? So if Kelvins HPs had an “issue” , was that before and after the heads were ported by different people? If you would actually post facts and not your bias opinion, you would understand the HPs were standard pushrod location heads. You can only get so much area in them, I don’t care if you are the Butlers, Dan Barton or Marcella. Kelvin didn’t want to run an offset valve train, so the “issues” with the heads was really the goals of the customer. The CV-1s filled that bill and out performed the previous combination even though you have said in the past, CV-1s have issues. Calvin Hill Hill Performance 708-250-7420 |
#968
#969
Auto Club!!!!
AAA Auto Club! |
#970
#971
Don’t work Jack,
We have you covered. https://midatlantic.aaa.com/membership# Merry Christmas and Happy New Year! Calvin Hill Hill Performance 708-250-7420 |
#973
... Oops- I had planned to keep quiet through all 49 pages of this trash...
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
#974
I know the feeling---you just can't look away. Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#975
I don't doubt there were gains with the guys you mentioned. But every situation is different. Now NA is the truth. I could not care less how any head does power adder myself. And when your stuff has not beaten Langer, Snyder, Rex with Tiger , Mike with E heads or slowbirds NA power how can you imply they will pick up across the board vs those PMD style (wideport) heads ? Put up big NA power with huge CR, 1.1" lift cams and carburetors, no computer controlled port injection and you will get your due. Now I believe some of the big dogs who wanted to upgrade their top ends would have chosen your stuff if your crew came off different and treated folks better. And that head would be more developed and in a better place now. Also some of the BS you guys have received was unwarranted. Had another casting run so it can't be all bad. E heads, KRE and even Tigers have been through crap too. I have never given the weight of Kelvins car a second thought. Don't put words in my mouth, little sensitive to that lately.(my fault) I am sure its a fine well thought out car. The facts are CVs had not beaten Mikes lowly E head number. Just go out and do it, no reason you can't. |
#976
It’s a train wreck ! But you can’t stop watching!
#977
Dragncar I suggest you research Fulton's NA HP in n20 tune. 13:1compression, cam optimal for N2O, smaller cubes than Mikes(20?), and low crankcase vacuum . Nearly 1100 HP.(1095)
What's it do at 16:1 or more compression and cam optimized for NA and vacuum where it should be? And the ports on this we're digitized @6-7 years ago. There are bigger "badder" ports available should an application call for it. The manifold is ported/cast not sheet metal. As far as conflicts... before you judge think how you'd respond to someone criticizing your product or service by someone who's not only never used it but knows little or nothing about your product or service. Throw in the mix those that just post up lies for "sport". And their is a huge difference between misinformation vs deliberate disinformation. If I find I've posted something incorrect I'll own up and try to correct. None of us are perfect.
Serious question, why do a lot these builds have vacuum issues?
#979
#980
Is it admitting not perfect , is it should have could have? Beats me.
