Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 01-15-2015, 10:10 AM
PONTIAC DUDE's Avatar
Post Pontiac Cam Dynamics mild take out cam: used
Good lobes. Out of an older rebuild. Specs from an old Cam Dynamics catalog.
Will include catalog cam spec sheet.
Hydraulic- good idle, daily usage, good fuel mileage. rpm range 2000-5000
#10507 Energizer 272H10 Group III
216 duration at .050 int/exh.
272/275 advertised int/exh.
Lobe centerline 110
Gross valve lift. .454 int/exh.
Can be used with stock valve & drive train. A nice mild upgrade over stock.
$35.00
Can include a set of new true Johnson hyd lifters for $65.00 more.
Also can supply a bottle of the Zinc additive breakin oil for $9.95
Best to PM me.
Old 01-15-2015, 07:18 PM
naughtygto naughtygto is offline
What is the most lift you can go on stock springs?
Old 01-17-2015, 02:20 PM
Post
Depends on the years of the heads and valve lengths, but have gone .465/.480 safely with stock springs and rockers. Rocker arm geometry with location of the tip of the rocker on the valve with the right pushrod length becomes critical. (milled heads valve job and lowering valve in head, etc) After that you might have to get into elongation the stock rocker arm slots.
Old 02-17-2015, 03:36 PM
Post
Bump
Old 02-27-2015, 04:08 PM
Post
Pica attached.
Name:	Pontiac cam 1.jpg
ID:	391504   Click image for larger version
Name:	Pontiac cam 2.jpg
ID:	391505   Click image for larger version
Name:	Pontiac cam 3.jpg
Old 11-22-2019, 04:32 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Did this ever sell ? It what we would like for our 350 P leftover parts budget build for a 76 Ventura (74 350 low mileage short block , 389 heads , headers , 3.23 gears )
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
Old 11-22-2019, 07:03 PM
77 TRASHCAN's Avatar
Larry, I've read here that Ken does business via Facebook. I don't have any interest in facebook. Maybe you can contact him there. I wish he was still active here. He was a great source of knowledge, he helped many here...
Shut it off
Shut it off
