Old 01-06-2024, 12:07 PM
tomaszek tomaszek is offline
Default Need one 1.66 valve
I’ve been looking for one 1.66 original type valve for a 69 350 head. I only need one and can’t seem to find the original type with the o ring type. I just have this one valve that leaks. It’s pitted pretty bad. I tried lapping it but no luck. I did find a t2850 valve on eBay and bought it but it the 1.96 larger valve. Any help is appreciated.
Old 01-06-2024, 12:18 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Can you tell me the over all length?
Go fast, see Elvis!
Old 01-06-2024, 12:45 PM
steve25 steve25 is offline
I have several very good used ones here .
They are about 5” in overall lenght.
If you can’t find or want a new one shoot me a PM and I will freshen up the seat on my grinder and sent it to you.
Old 01-06-2024, 12:58 PM
Length around 5.015
Old 01-06-2024, 01:07 PM
Is that overall length measured with the valve face cleaned up?
Old 01-06-2024, 01:18 PM
Sealed power list two different 1,66” exh valve lengths for a 69 350 or 400.
v-1823 is 5.082” tall.
V-1832 is 4.984” tall.
Both of these I see right now on EBay.
Old 01-06-2024, 01:50 PM
Oh boy. Ok I’ll have my dad clean them and measure all four. Does that small difference actually matter. It’s so close.
Old 01-06-2024, 03:10 PM
Either one would work for you depending on some factors, like what head gasket are you using when you reassemble the motor?
What is the casting number of the heads you have?
Old 01-06-2024, 03:31 PM
Well the casting is rusted to the point where we think it’s a 17. Or 47. As for the gasket. It had a felpro 8259 gasket when it was removed.
I planned on putting the butler gaskets. The universal one. I forget the part number.
Old 01-06-2024, 03:33 PM
SPM-19375-2 Is butlers gasket
Old 01-06-2024, 05:48 PM
Average of all 4 valves. Cleaned up is 5.012.
Old 01-06-2024, 06:45 PM
The valve I have is exactly 5.015” long, so it’s fine to use.
Let me know if you want it.
