Rear Springs
I need rear springs for my 72. The one from Ames will be to low. What springs are you guys using on 68-72 A body with 275/60/15? Pictures would be helpful.
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
The Following User Says Thank You to gman005 For This Useful Post: | ||
Coil Spring Specialties will build you custom springs. I had purchased the 'correct' rear springs back in the 90's and as most here know, that gave a tail dragging look.
I asked CSS to make some .75" over stock. Pulled the 'correct' one's out, put the custom one's in and the height was raised .75". https://coilsprings.com/classic.aspx |
The Following User Says Thank You to The Champ For This Useful Post: | ||
My new rear springs (2012? Or 2015?) from Ames were too low.
I used a pair of Vista Cruiser station wagon rear springs on my 69 GTO when I was running 305/50/15 rears.
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
I use Eaton cargo coils on my 1972 LeMans vert with 275/60/15 tires on the back and they work well. The tires jack up the rear slightly.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
The Following 3 Users Say Thank You to AG For This Useful Post: | ||
Moog CC501 Cargo Coils work very well.
The raise the rear just slightly and stiffen the ride a little bit. No more sagging.
We've used them on ALL our 1968-72 A-body and 1969-72 G-body stuff. https://www.amazon.com/Moog-CC501-Co.../dp/B000COMSYK |
The Following 2 Users Say Thank You to Joe's Garage For This Useful Post: | ||
Joe do you have any pictures of ride height?
What about cc507?
If your Ames springs are too low, easy to find an insulator kit for upper and lower that will help boost the rear up a bit instead of replacing the springs.
The previous owner of my car replaced the front and rear springs shortly before I purchased it, I believe they’re Dorman springs. They’ve settled down a little since these photos were taken. Sent from my iPhone using Tapatalk |
Got my rear coil springs from Jeg. 275/60/15 MT. 10" rims with 5" bs.
The rear springs in my car have those adjustable bolts in them now. They were in there when I bought the car. I was going to buy the moog CC501 and the CC507 and return the one I do not need.
68WARDOG Do you know the part number you bought?
MOOG 6319.. I didn't want that " jacked up" look, since I have a narrow than stock Ford 9"
Thanks.
I see those springs are for a 4 door.
68Wardog Can you measure from the ground to the top of the wheel opening? My car measures 28.25".
I'm only 27.5
Thanks for checking. Those should work.
VID can you measure your car?
These are BMR 2” lowering springs with 275 Hoosier drag radials on 15x8 Rally’s with 4-14” BS.
68 GTO,3860# Stock Original 400/M-20 Muncie,3.55’s 13.86 @ 100 Old combo: 462 10.75 CR,,SD 330CFM Round Port E's,Old Faithful cam,Jim Hand Continental,3.42's. 1968 Pontiac GTO : 11.114 @ 120.130 MPH New combo: 517 MR-1,10.8 CR,SD 350CFM E's,QFT 950/Northwind,246/252 HR,9.5” 4000 stall,3.42's 636HP/654TQ 1.452 10.603 @ 125.09 http://www.dragtimes.com/Pontiac-GTO...lip-31594.html |
