#661
It is a nice part,best thing is you don't have to worry about bending it.I had to trim mine a little more because the heads were milled and shortblock decked.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 08-02-2017 at 01:50 PM. |
#662
Easy tech on testntune nights.There are usually quite a few newer cars especially the Mopars running in the 10's.I do have a SFI balancer,flexplate,proper lugs on the axles.I've been torn between putting a rollbar in this one or find another roller that is setup.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 08-02-2017 at 01:45 PM. |
#663
Engine looks great, you are almost there!
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
#664
Thanks take man I am going to pick one up, like the idea of not bending, looks great too!
71 Goatman Hot Rods & Horsepower.......A diease for which there is no cure. 71 GTO, 463, SD 295 d-port heads, 10.75:1, RPM intake, 502hp/560tq @ the crank, 200r4, 10" Continental convertor, Bullet 234/244 cam, Cliff's Q-Jet, 3:42's w/Eaton True Trac, 5 Power Tours. New performance numbers coming |
#665
If TA Man went to 3.42 gears, he might be able to run 10.50s. Now that's haulin'. He may do it anyways with the 3.08s.
#666
What many don't realize there is a bit of a trick to my setup,my th 350 has a 2.75 low gear set..So if one does the math my th 350 and 3.08 gears has the same effective first gear ratio as a th 400 and a 3.42 gear. Hopefully all the changes are positive for my milder gear/convertor combo. More head flow with small port volume More intake flow with small runners More compression from 10.1/10.2? to 10.75 More valve lift Lighter valvetrain, Near perfect port match, Lighter rotating assembly ,pistons weigh 420grams,pins 109,(compare to 800grams plus for TRW's and pins) Zero decked block Shortblock hard blocked to bottom of water pump
#667
What octane gas did you use before? Do you think you will to step up octane number now?
#668
Always ran well on 87....no issues..I plan on running 91 octane in it..Track days add some 94..
#670
Same heads from 2009.Dave did the 305 CNC port program on them,cut them to 79 cc's,new springs,retainers,keepers,cups valve seals.Dave also did some minor work on the intake opened it up slightly to match the heads..The head/intake mating surfaces were also milled to fit.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 08-05-2017 at 12:14 PM. |
#671
With the same cam/heads my car runs well with 91 octane , never tried anything less. However, when running less than 93 Octane from the local BP station, I do experience engine run on or diesleing. Base timing is 12 degrees at idle, so not entirely sure what is up with that... 93 takes care of it, so have not pursued any other remedies.
Sent from my XT1585 using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
#672
What is your compression ratio?
#673
Doing the math, it comes out to 10.5 if I recall correctly. Doing the math, it comes out to 10.5 if I recall correctly.
#674
New build is alive,just did a quick fire up..scared the dogs in the house the wife thought it was thunder!Fired up quick!Test drive tomorrow!
#675
Good luck!
#676
who did the port work? I'm always fascinated at how you get more head flow with a small ports. Any tricks you can share? Good luck on your next outing. |
#677
For interest I'd be interested in the runner volume myself. My notes on another build suggest a set of Dave's 310 cfm KRE heads were about 204 cc's. Maybe not typical but my set of Edelbrock heads ported to 313 cfm at .600" were about 227 cc's.
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 08-10-2017 at 10:05 AM. |
#678
Steve,I don't have the exact port volume but I can ask Dave.I believe they are in the 204/205 cc range.This will give you an idea,the intake gasket used is a SCE 128103 which is 1.125 x 2.275.
#679
All head port work was done by Dave Bisschop at SD Performance using his 305 CNC program.Dave also opened up the intake manifold for a perfect match,as well as milling the heads to raise compression. He also milled the intake side of the head and the intake itself for a perfect fit. Initial plenum and port work of my Torker 2 was performed by Derek Stewart last year.
#680
Next time you have the intake off double check that gasket port height. Despite what the catalog states I have found the SCE 128103 intake to be about 2.320" tall. I've pointed that out to SCE on at least two occasions. The last time the fellow pulled one off the shelf and measured it while on the phone and agreed.
