Old 11-16-2008, 10:44 AM
FSJplumcrazy's Avatar
FSJplumcrazy FSJplumcrazy is offline
Question What makes paint crack?
Fresh paint...well maybe a month old now, but what makes a paint crack like this with no filler underneath?
I'm in the process of putting the wire harness in and found it when I crawled under the car to route the starter wires.
Wayne S
Nothing is impossible, impractical maybe, but never impossible.
1966 Le Mans Convertible STATUS: *In Progress*
389 (sixty over)/200-4R/10 Bolt (3.08 for now)
My other ride is a 71 Jeep J4000 Pick-up Truck with factory Buick 350/Th400
Old 11-16-2008, 10:56 AM
wytnyt's Avatar
wytnyt wytnyt is offline
my guess would be a grease or foreign substance or just poorly prepped surface underneath
Old 11-16-2008, 11:43 AM
paint guy paint guy is offline
I agree with wytnyt.that paint is way too new to crack from "old age",most likely some kind of surface contamination is my guess also.you might be able to repair it,in just that small spot,and it would be an easy and quick repair.I'd watch it for another week or so,before I started the repair just to see if it gets any worse.Your'e fortunate that its a solid color and its down low,you can "cheat" a little bit on the repair and no one will ever notice.
Old 11-16-2008, 12:28 PM
Cammer-6 Cammer-6 is offline
If youre going to repair it I would explore with a fresh razor blade.
Cut a V groove on each side of crack ,then fill with paint.
May take a couple of applications to fill it.
Old 11-16-2008, 01:06 PM
wytnyt's Avatar
ill bet its loose from he surface at least 1/2 in around it,hardly ever just a crack
may be able to use a syringe with super glue and contain it.
dont laugh,ive had to do it
Old 11-16-2008, 02:22 PM
Probird's Avatar
Probird Probird is offline
Too much hardner in the paint?
Old 11-16-2008, 02:35 PM
sleepy's Avatar
sleepy sleepy is offline
Might have been put on to thick per coat WITH to much hardener.
Old 11-16-2008, 03:03 PM
wytnyt's Avatar
most any imbalance of mixing components can cause severe reactions,but being its localized to one spot,,id go with bad prep
Old 11-16-2008, 06:16 PM
GREATGTO's Avatar
GREATGTO GREATGTO is offline
yeah looks like delamination due to poor prep
Old 11-16-2008, 07:58 PM
GT182's Avatar
GT182 GT182 is offline
Agreed.
Too heavy an application will do it too, but it would show in a larger area if that was the case.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 11-17-2008, 12:44 AM
PaulatFast PaulatFast is offline
I vote for poor prep as well. What it was I don't know, but I'd bet it's not the paint! I'd be worried about the rest of the car!
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
Old 11-17-2008, 01:07 AM
My thought exactly.
Mike
former." --Albert Einstein
- Winston Churchill
Old 11-17-2008, 01:37 AM
given the normal elasticity of urethanes when done properly I would have to agree with the hardner and too much paint at once in that area.
Ive painted visqueen poly sheeting and it never cracked or flaked off but it was thinner coats.
Old 11-17-2008, 01:49 PM
Thanks Gents...I gave the body shop a "heads up" on the area and they told me they would stand behind the paint, so when I get her up and running (or closer anyway) I'll drop her off for repair.
Wayne S
