Old 03-07-2007, 09:49 PM
FSJplumcrazy's Avatar
FSJplumcrazy FSJplumcrazy is offline
Question Calculators
Any RPM calculators out there...I can find several for a 4x4, but have not found anything for RWD.
Wayne S
Nothing is impossible, impractical maybe, but never impossible.
1966 Le Mans Convertible STATUS: *In Progress*
389 (sixty over)/200-4R/10 Bolt (3.08 for now)
My other ride is a 71 Jeep J4000 Pick-up Truck with factory Buick 350/Th400
Old 03-07-2007, 10:01 PM
BILTIT's Avatar
BILTIT BILTIT is offline
What kind of RPM calculator?
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 03-07-2007, 10:02 PM
Bill Hanlon's Avatar
There are tons of RPM calculators on the web. Just type "RPM calculator" into Google. Two wheel drive, four wheel drive, eight wheel drive or one wheel drive, makes no difference.
Old 03-07-2007, 10:03 PM
This one is the best, plug in your tranny and tire size, but it only works if you know what transfer case you have (4x4 only I guess)
http://www.grimmjeeper.com/gears.html
I'm not that computer literate, but couldn't this be modified to figure out something for us?
Wayne S
Old 03-07-2007, 10:04 PM
BILTIT's Avatar
http://www.wallaceracing.com/Calculators.htm
Derek B.
Old 03-07-2007, 10:11 PM
That one is ok if you know your final gear and the tire diameter, but what if you want to try different tires, trannys and don't have the information on hand.
Grimm's is nice because you can run two side by side with different tires or trannys or gears and see the difference between what you have and what you may achieve.
I guess I want my cake and eat it too
Wayne S
