Old 02-03-2008, 04:27 AM
jtherr0 jtherr0 is offline
Yep, it goes forward in every gear selection. No reverse, no neutral. Not sure if it matters, but the Transpak was installed with the transmission out of the vehicle. It worked perfect before I tore into it...
Also, it seems like it gets hot very fast. I installed a B&M Supercooler too, and within 5 mins of running it's already pretty warm.
Old 02-03-2008, 08:36 AM
stevep's Avatar
stevep stevep is offline
Drop the pan and see if the manual valve is properly positioned (or connected).
Old 02-03-2008, 08:50 AM
RAIV55 RAIV55 is offline
Yeah, my thoughts too.
Old 02-04-2008, 04:42 AM
Thanks, I'm going to tear it apart again tomorrow and see how mis-aligned it is. I installed it with the transmission upside-down, so maybe in the process of flipping it over something came loose. One other question, think it's alright to reuse the fluid I take out? It only has .01 miles on it!
Old 02-04-2008, 08:37 AM
stevep's Avatar
As long as it is clean and you drain it into a clean container, no problem.
Old 02-04-2008, 09:05 AM
kickin wing's Avatar
kickin wing kickin wing is offline
Send a message via AIM to kickin wing Send a message via Yahoo to kickin wing
Angry
I'm hopin it's that servo spring. The last time I worked on my trans I had the
manual valve hooked up but I forgot the servo spring. But had no gears that all.
The other 2 times I had 1st through out WITH the servo spring in and forgeting
hooking up the manual valve. But I forgetting the servo spring is my own fault.
I'm hopin it's nothing else.
Old 02-04-2008, 09:55 AM
TTS's Avatar
TTS TTS is offline
The servo return spring isn't the problem. If you left the servo piston/ pin out- that would be a problem.
Old 02-05-2008, 08:52 AM
Exclamation
Well it's the servo spring only I forgot, not the servo piston.
Old 03-27-2008, 03:40 PM
Thumbs up
Fixed!
Old 03-27-2008, 05:26 PM
Kyflier Kyflier is offline
Well spill the beans, what did it take to fix it?
Kenny
Cincinnati, Oh
1971 Ventura II
400 .060 Eagle Rods
Old 05-09-2008, 08:43 AM
Exclamation More trouble...
Well it great for about 4 weeks. And now it won't hold any gear but 1. It'll shift
hard 2 and 3 but I'll slip out of 2 and 3. And when i it's in 1st doing 30 it slips alittle.
But Reverse works fine.
